Cal,
The drivers are TAD, see here: http://www.diyaudio.com/forums/showthread.php?s=&threadid=7032&highlight=
The horn is diy, descripion also in th thread.
History for choosing this project:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=6164&highlight=
http://www.diyaudio.com/forums/showthread.php?s=&threadid=6083&perpage=15&pagenumber=1
behind the port you can see the piece of wood that is used to make the corner of panels of plywood.
The ports tuning is not ready yet, Kent at passlabs wants to make some measurements at his enclosures, and i´m notz sure how to tune at the moment. I made this:
http://home.tu-clausthal.de/~tpa/port/index.html
But conditions for measuremnt are very bad in the room i use at the moment. So the measuremnt doesn´t tell too much.
>As for namecalling, I was not going on about anyone personally, I referred in robust anglosaxon to a commonly repeated chestnut of a pseudo theory on >acoustics.
As your post was deleted, we don't know which chestnut you refer to - can I guess that it was the one abou how you can't hear 20Hz unless your room is 500m long?
originally posted by Kuei Yang Wang
And this theory remains exactly what I analysed it as (in the strict chemical sense I may add) no matter how often repeated by those who prefer to parrot others poorely researched and argued theories as fact because they seem to fit with personal prejudices, instead of informing themselves about the facts.
I don`t want to begin an off topic discussion about semantics and what is rather rude manner of expression or what isn`t .
The above is all true - but still though - there are other and IMO better ways (more polite or respectful if You will) to proof others being wrong (and apparently I`m not the only one feeling this way).
I understand that everybody can just have had a bad day... so case closed what concerns me
Konnichiwa,
Yes, the sameself one. BTW, it would also mean you cannot hear 20Hz unless your ear channels are 17.25m (the wavelength of 20Hz) long.... In fact, if that theory held the least bit of water you hear nothing below something closer 2KHz, which most people actually. Though for those who don't it may explain the view that "small speakers are just fine".... ;-)
Sayonara
bremen nacht said:>As for namecalling, I was not going on about anyone personally, I referred in robust anglosaxon to a commonly repeated chestnut of a pseudo theory on >acoustics.
Sayonara
KYW - I agree with all of what you have said about drivers appart from one thing. And unfortunately for me as im sure im gonna get an ear bashing for it, as you anglo saxonismed it before LOL, is the 20hz in the ear canal.
I do understand that obviously we can hear down to 20hz with headphones. But I have heard time and time again, that with a smaller room it is harder to get a flat response down to a given frequency. Not that you cant hear or produce a low freuquency in the small room, but more you have got to move more air in the smaller room then a larger room for the same SPL at low Hz.
If this is not really the case, then it must have been simply room interaction other then the above, that contributed to the improved low extension when I moved my speakers into a larger room.
Cheers Matt
Cheers Matt
Matt
Your are correct, you cannot here low frequencies in your ear. You are feeling sound pressure of the pulse.
If fmin = V / (2*L) = 172/ L is used in determining the room modes or resonaces. And this is obvious since, the bigger the room it is, the lower the modes and less troubling.
What I am saying is. A certain frequency can be produced properly only if the associated wavelength "fits" in a room's dimension. If L = V / f, so you need a minimum length of 17.2m. for a 20hz frequency to be produced properly. Other wirse are your lessening to standing wave and room modes.
http://www.mcsquared.com/metricmodes.htm
http://www.linkwitzlab.com/rooms.htm
thylantyr said:
I'm going to use six 15" in my home stereo project because
I like it.
Good for you. I use 8 12" myself.
.....and my plan is to use 8 (4 per channel) 10" long-throw Scan-Speak`s.Originally posted by Bill Fitzpatrick
That`s an equivalent total diaphragm area of approximately 4 times a 15" driver - but with much higher linear X-max. than 15"ers usually can do
Konnichiwa,
Actually, VERY LOW frequencies (these below the lowest room mode) are easy peasy. It is more interesting in the range where the room is modal (I would link here my little treatsie on using the Behringer EQ in if Yahoo would not prevent me from sharing it - the salient points are reposted below), meaning subject to many pertubations due to the room modes.
Actually, two easy soluitions exist for room modes:
1) Parametric EQ's (digital or other).
2) Use of Dipole (figure 8) or Unipole (Cardiod) woofers.
Sayonara
Behringer and room acoustics treatsie:
http://groups.yahoo.com/group/Thunderstone_technical/files/TL Circuits/Ultracurve/Behringer target curves.html
5th element said:I do understand that obviously we can hear down to 20hz with headphones. But I have heard time and time again, that with a smaller room it is harder to get a flat response down to a given frequency.
Sayonara
dipole subs
So KYW, it seems you are saying that dipoles are a good way to go for subs. What do you think about the W and H shaped open baffle dipole subs like these? They seem like a good way to make the cabinets smaller (ie, turning the 15-20" drivers sideways).
My favorite 15" woofer.
http://www.lambdacoustics.com/drivers/TDdrivers.html
Specifically TD15H Apollo motor. The picture shows the old phase
plug, the newer ones are much longer - a manly woofer - lol
The sonics are superb when listening to it full range.
I should have a total of ten of these soon.
/yummy
I think this is the old protoype chart of the TD15X.
http://www.lambdacoustics.com/funstuff/TD15X.html
The DIY section of his website. This looks fun, unity horn.
http://www.lambdacoustics.com/images/unity/family/pspkr.jpg
http://www.lambdacoustics.com/images/unity/family/majestic ladies.JPG
/yummy
These TD15H Apollo look cool, The only thing I did not care for was the PVA Coated Foam Surround.
I have heard the Focalsand the red magnets look cool. I wood have a had time parting with the cash for a driver that cost so much with out having heard it. So I am out of luck.
http://flexunits.com/iz.asp?id=4|a|119||| these units look nice but big bucks.
cocolino said:
When You replace the word music with the word bass above I fully agree with this.
Actually IMHO all the way into the lower midrange.
At the moment I am using 2 15" woofers per side in open baffles,
from ca 40 to 270Hz , horns cover the rest.
cheers
- Is15 inch overkill for music?????experts
