Hi Frank,
well the circuit is virtually built, I didn't want to subject the 3a5's to this voltage incase they went lunar.........
The 170v at b+ with no load worried me, given that the max for the 3a5's is 135v, so I thought I'd ask before having to fork out for new tubes....
Do you think the tubes will be okay if i Just test the rail with them connected?
Incidentally I did use a light bulb across B+, it was a 60w 240v type, the voltage at B+ fell to 21 volts or so...?????
thanks
Raja
thanks
Raja
They won't melt if it's only for 30 secs but if you want to play it safe then up the value of R10 to 1K and work backwards using, you guessed it Ohms' law.
Or use a linear 1K pot of say 3-5 Watt and connect the wiper to the output.
Set it to 1K, let the circuit warm up, adjust for 110V...switch of and measure the resistance across the pot.
Replace the pot with the closest matching R.
I can't remember the exact resistance but is pretty small indeed since it dropped the B+ from 170V to 20V...
Too lazy to do the maths...hey, it's Sunday.
Frank forgot to mention the wattage of the light bulb but you should know that a 60W light bulb is not equivalent to a 470kohm resistor.
