Is PSUD II trust-worthy or not?
integral \in-ti-grel\ adj 1 : essential to completeness 2 : formed as a unit with another part 3 : composed of parts that make up a whole 4 : ENTIRE
Which of these meanings did you have in mind? A number essential to completeness? A number formed as a unit with another part? A number composed of parts that make up a whole? An ENTIRE number?
Or the obvious meaning left out by your dictionary, being the result of a mathematical process of integration?
Enough ppl have understandable difficulty with technical English here without unnecessarily complicating matters.
You meant "integer". I won't insult you by posting its dictionary definition.
Ian
Question about the Load the PSUII is asking for.
Can be A (mA) or Ohms (makes big difference).
From each Filter section current flows into the circuit.
Say: I have 15mA current going into the 5 filter sections (the L R and C)
How to calculate the right Load resistance at the end?
The Psu gives mostly a 5K. Where did he get this from . Made up out off …?.
