I have a JBL sub that has a preamp and its about 15 years old. I had a new speaker installed a year ago and it has never played as well since. It clearly will not play as loud as it did new. As a matter of fact I have it turned up all the way and before it would have shook the windows. I also have the output from the home amp feeding it at it max also. I'm thinking I need a new amp or could it be a poor speaker? Its a 12" sub...
Thanks in advance for any input.
Terry
Terry
One of the first things you'll learn here is that you can't stick any driver in a pre-made box and expect it to sound it's best.
All speakers have things called Thiele-Small parameters. You don't need to worry about what they mean, but you must remember that they define what kind of box a woofer likes, how large the box will be, etc. The parameters differ for different woofers, therefore, a box that sounds good with one woofer will (90% of the time) sound rubbish with a different woofer, or, at least, sub-optimal.
And to complete the conversation... much more detail is required to provide an answer for you. Just saying it was a 15 year old 12" JBL doesn't assist us in helping you. There are three ways to fix a loudspeaker (the whole unit, driver + cabinet). Either take the driver to have it reconed to the same original specs, select a new similar T/S parameter driver or design a new cabinet for use with a new driver. Just slapping some whatever replacement in your old cab will result in exactly what has happened to you.
Well I did not realize its not as easy as tossing a speaker in a box and adding watts.
OK, well I think about and I had the speaker reconed. Will what I know and what I'm telling you, would it be safe to say the amp is fine and its more to do with the combination of box amp and speaker?
