Last time I checked those were hideously expensive though.
Different thought: Did you consider to use a Peltier cooler element ? This element is cooling on one side by the use of electricity.
Joined 2002
grataku said:That's right, if you do some calcs you can put that resonant freq above the audio range where it would matter even less that the little it already does.
Not to mention that it's much easier to damp.
se
fdegrove said:In the real world that won't be feasable.
Besides I don't even feel it's advisable to go down that path, what you want is sufficient mass so that the whole doesn't resonate at the slightest wavefront.
Adding mass doesn't make it less resonant. It just lowers the resonant frequency. So unless you're able to get the resonant frequency well below 20Hz, you're not going to accomplish the goal.
I found add some layer of lead foil to add mass and damping of side and bottom panels is usually very beneficial.
That could work with big flexible panels. But don't see it working too well with the tiny chassis that are more typical of Gainclones. Because the panels will be much smaller, they'll also be much stiffer which means their resonant frequency will be higher which means it will require adding quite a lot more mass to get the resonant frequency well below 20Hz.
se
I have to ask the question, is there any real performance increase by super cooling the chip beyond normal heat sinking.A properly running clone runs very cool and i really find it hard to believe that further cooling would actually improve the sound.
I believe that resonance and vibration control would actually have a greater impact on overall performance than additional cooling.
I mean are we really going to start floating the chip in liquid nitrogen or some other means to get a .001% increase in performance?
ron
ron
When I started this thread, I wasn't concentrating on supercooling, but on using a reasonable amount of heatsinking surface to dissipate only enough heat. Depending on the music you listen to and volume level, the small size amp might run cool, but when you push it, it can get hot too, I mean Aleph hot. My amp is 8.5 x 6.5 x 2", whole aluminum, no additional heatsinks and I used to have it warmed up to at least 40 deg C on some occasions.
I did more thinking and I'm pretty much set on using copper pipes for heatsinking. They are easily available, easy to cut (straight) , can be soldered and copper is very good heat conductor, not to mention that it probably sounds better than aluminum. I will cut 1" or 2" dia. pipe to req. length, solder flat copper piece to one end and mount chip there. Will also see if filling pipe with sand brings any improvement. The pipe will be mounted in some sort of acrylic or wood frame. No separate PS this time.
Peter Daniel said:I did more thinking and I'm pretty much set on using copper pipes for heatsinking. They are easily available, easy to cut (straight) , can be soldered and copper is very good heat conductor, not to mention that it probably sounds better than aluminum.
yes, copper does sound better than aluminum. Have you tried gold plates or gold bars? They do wonders to sound too.
Empty Vessels....
Millwood, have you actually tried different heatsink materials ?.
By the tone of your reply I think not.
If you do have something sensible to say then say it, if you do not then don't, ok.
Eric.
millwood said:yes, copper does sound better than aluminum. Have you tried gold plates or gold bars? They do wonders to sound too.
Eric.
Fans Are Cheap And Easy.
Peter, there are plenty of cheap and very small DC fans available nowadays, that can shift air efficiently and very quietly.
In my experience there is nothing like forced air movement to keep temperatures down.
Just gently forcing air through your case will help dramatically to keep a lid on case and device temp.
Somebody posted a clever and elegant circuit here recently that uses an NTC thermistor and a LM317 to control fan speed.
Fan noise reduces and longevity increases markedly with reduced fan speed, and as far as I am concerned constant heatsink temperature is a very good because device thermal conditions are kept more constant.
I have heard one well respected designer say that a particular temperature sounds best.
Eric.
PS - Graham Pratt has shown some photos with the active devices mounted to a copper block that is then mounted to (and insulated from) the aluminium heatsink, and I think this is a good compromise over using copper heatsink only.
Eric.
This is certainly true for Class A designs.
I read this somewhere too and most designers I know don't dispute this claim.
The only trouble with fans ( in general) is that they are notorious dustcollectors.
Re: Empty Vessels....
Eric, could I ask you to think again?
Yes, I have. currently, I am trying out different CPU heatsinks, with or without fans. the ones I have tried out are copper, aluminum, aluminum with copper shims / plates, and annodized aluminum. I have also tried out steel (using an ATX PS case).
In yesteryears, I have tried aluminum bars, steel plates, cast iron (a piece of radiator, ), oil-filed steel (another piece of a radiator), water / alcohol (evaporative coolers).
Gold, with its superior heat conductivity, great density, and cosmetic appeal, would make a super heatsink and vibration damper. Wouldn't you agree?
Eric.
I don't get this...
How can gold damp vibrations?!
On some sorbothane feet?
SY said:Real men use diamond. Best thermal conductor and you don't need insulator pads. Low heat capacity, though, and that's just as important as conductivity.
high conductivity and low thermal mass would mean that it is best used as an insulation pad.
a high-end chip amp, mounted to a gold bar heatsink, isolated by diamond pads, that is your $1 million amp! Forget about those lowly resistors or capacitors,
Re: I don't get this...
I thought we had established that you need a lot of mass to damp vibration earlier in this thread. and gold certainly is heavy.
plus, it is quite soft and thus being able to deform -> absorbing direct hit.
Re: Fans Are Cheap And Easy.
That's interesting.....could tell us what it is...
mrfeedback said:I have heard one well respected designer say that a particular temperature sounds best.
Re: Re: I don't get this...
I would lose my time in trying to reduce transformer vibrations (if it's in the same box, that is).
Trying to damp vibrations of a chip with metal is not my field.
Or one day people will substitute the schock absorbers on their cars with spikes.
And the tires with metal cylinders.
- Chip Amps
- Is LM3875 chip waterproof?
