Is it safe to start (power up) tube amp with tubes removed?
Administrator
Joined 2004
Hi sumotan,
Previous replies are bang on. You can never power up a tube amp with an open load. It can even punch through the insulation in the output transformer (= dead transformer) and cause the output tubes to arc (can wreck the tubes). So the damage can be quite severe for simply forgetting to connect a load to the amplifier.
-Chris
