Is cone movement only proportional with Sd?
The cone will move the same amount of air to generate a given output level at a given frequency, regardless of sensitivity, if that's what you're asking. Sensitivity will not change how much the cone moves to generate that output level. However a more sensitive driver might move further (and produce higher SPL) at a certain input voltage. But that's confusing the issue, which is how much air you are moving.
Is cone movement only proportional with effective surface area and frequency?
unfortunatly - not exactly. and sensitivity isn't main problem there.
some parts of cone moved nonsynchronous and as result we've distortion and .... different timbres appeared. :)
there are many equipment will be able to control. we're using Klippel system for understanding what is going on during sounding - we can see process of mooving any part of cone as well as different wave invoke different effect. very effective :)
