IRS2092 How to drive more then one pair of output transistors?
In the original datasheet there is only one pair of transistors. How can I wire 4 pairs of transistors like in this picture.
the layout looks great !!!!
but for a class AB amplifier only....
i wonder if we can see with a scope the signal on the Drain of the top MOS-FET's, close to the small 12V connector.
how many Watts they are able to deliver ???
Hmmmm I think this is class D amp. It uses IRS2092.
I would really like to hear if someone has made this.
The problem is that I can't find the schematic ANYWHERE. I only dig this PCB layout. So we must build it to test it :D
I'll try and draw the schematic in eagle from this PCB.
I have more info. Here is everything I could find nd IT WORKS. It is also commercial.
  • classDv1[1].pdf
Use SMD (SOT-23) local buffer transistors (emitter followers) for each output MOSFET.
Although, this layout may work, parasitics make switching much slower resulting in much worse efficiency (and higher distortion) than in a proper SMD layout with 2+ layer PCB.
Parasitics will also limit the maximum rail voltage for safe operation.
3000W are possible with just four IRFB4227 when layout parasitics are low enough.
