li_gangyi said:ermz...he wants Aluminium Oxide stuff...and there's no digikey in Singapore...sorry...
As far as I could tell neither the original question nor the second post by castlesteve, the thread starter, mentioned anything about Aluminum Oxide pads. I simply suggested Digi-Key as a supplier for Silpads of the correct size. On top of that I have no idea why a person in N. Virginia would turn to a Singapore source when he is in the U.S and what he wants is readily available.
Could be my mistake.
Hi All-
I recently priced the AAVID Thermolly insulator by the roll (50 ft.).
The 2 mil thick was $351.00 USD a roll!!!!
After to I recovered from my heat attack I politely said no thanks and am looking for another avenue.
I have not had any luck searching the Digi-Key site for "MultiWatt silipads" as UrSv mentioned.
Is there another name or title the pads could be listed under?
rabstg said:I have not had any luck searching the Digi-Key site for "MultiWatt silipads" as UrSv mentioned.
um, try harder?
i think the search term you want is sil-pad. or just use "pad" in their rather good search engine and whittle down from there.
i mean this most kindly of course. is the one you want in those results? digi has a lot of thermal pads.
Hi-
I don't know you "ofb" so I will be polite here...
After searching multiple times I called Digi-Key and "Nick" the Tech support guy and Claudia the sales rep could not find ANY insulating pads on their site that were larger than TO-220.
The size needed is TO-220-11.
PS, if you call that a good search engine you haven't Googled...
no reason not to be.
one thing the digi engine doesn't do is give a result page link, so try this, search with sil-pad, check off Items In Stock, then apply filter to-3. i get eight results. is there a reason you can't cut these down per peter's suggestion? or there something else in the way here?
and isn't to-220-11 the same width but slightly shorter than to-220? digi has a lot of pads for to-220 if that's right.
TO-220-11 is the pin package, same height as the TO-220 but WIDER.
Sil-pad makes the Multiwatt pad (sufix -125) that is the correct size, but neither Digi-key nor Mouser carries it.
I have written them and requested the nearest distributor.
Cutting pads only works in small quantities and when done by competent people. To be included in a kit it needs to be the "right" part.
- Chip Amps
- Insulating Pads.
