Mark,
The new Alpair 7.3s come with a super gasket that makes the driver instalation easier.
With other MA drivers I've used, the gasket was separate from the driver - for isntallation I used to glue the gasket to the baffle hole and screw on the driver. So, if I were to use the same driver in a different enclosure another set of gaskets would be good enough as there was no contact of the adhesive to the driver.
Now the super gasket is fixed to the underside of the driver frame. If any adhesive is used, then I fear it will be difficult impossible to remove the driver once installed.
Any suggestions on how to proceed? I have a Mar-Ken 7.3 cabinet nearly ready, which should be the home of the A7.3, but would also like to the drivers in a FH Mk3 with removable supra-baffle.
-Zia
-Zia
