I don't like motor potentiometers, especially if there are cheap and small attenuators but big motors.
But big blue alps like ebay item No 350430125063 or
Alps Motorpotentiometer - hifituning24.de
only a bit better.
Here an overview of various additional examples
A: RC Motor Analog-Potis
1) Velleman K8022 PASSIV Preamp with remote control
http_www_velleman.eu/distributor/products/view/?id=345984
associated RC transmitter:
http_www_velleman.eu/distributor/products/view/?id=374092
2) RCLL, Remote Controlled Line Level Volume Control
Audioplex RCLL-1 Remote Controlled Line Level VC
http://www.audioplex.com/RCLL1 revised.pdf
3) VolControl, Volume/attenuator control board
Dantimax (elektronik) - Control_boards
4) MK161 - IR 2 Channel Remote Receiver Kit
MK161 - IR 2 Channel Remote Receiver Kit - Ramsey Electronics
5) TentLabs Volume control
Volume control
6) MV-04 motorize remote volume control
DIYCLUB
7) Remote control audio kit
Dantimax - Remote control audio kits
B. Remote Controlled Switched Resistors by Relay
1) The remote control paratactic volume control
2) Audio Volume Relay Attenuator with IR Control
3) Remote volume control board, using relay - Halcro also use relay on their DA10 pre amp
DIYCLUB
more kits:
DIYCLUB
For me a better option are semiconductor versions without mechanical devices for the attenuation like this:
Digital Potentiometer
Digital Potentiometers and Capacitors (ISL22317)
Digital Volume Control
Volume Control - Volume Controls (CS3318)
2-Channel 78 dB Audio Attenuator
LM1972 - Micro-Pot 2-Channel 78 dB Audio Attenuator with Mute
Stereo Audio Volume Control (PGA2310-2311-2320-4311)
Audio - Volume Control - PGA2310 - TI.com
Electronic Audio Attenuator dc controlled (MC3340)
http://www.datasheetcatalog.org/datasheet/motorola/MC3340.pdf
MAS9116 - Stereo Digital Volume Control
MAS9116 pdf, MAS9116 description, MAS9116 datasheets, MAS9116 view ::: ALLDATASHEET :::
Dual-Channel Digital Volume Control with CMOS switch 4066
http://www.electronicsforu.com/efylinux/circuit/feb2003/aug99_dualchannel.pdf
Digital controlled stereo audio processor TDA7313 (ST)
http://ampslab.com/PDF/tda7313.pdf
http://www.st.com/stonline/stappl/p...type=4&tname=TL_DATASHEET_TREE_X_DOC&latest=N
Maxim DS8102 - the new volume control chip
DS8102 Dual Delta-Sigma Modulator and Encoder - Overview
DIY: high end DAC and digital volume control | Flickr - Photo Sharing!
TDA7439 (Linn Kolektor) THREE BANDS DIGITALLY CONTROLLED AUDIO PROCESSOR (ST)
http://www.datasheetcatalog.org/datasheet/stmicroelectronics/4291.pdf
Who knows URLs, where I can order Kits (similar to Velleman) where such IC's (ore discrete glue logic stuff) is in use?
Examples, that I have found, are this:
1) Remote Controlled Stepped Attenuator
Welborne Labs Remote Controlled Attenuator
2) RC-16 Remote Volume Control (looks like that one from Cyrus III and Cyrus IIIi / Cyrus 3i)
http://www.oxmoor.com/files/cut sheets/DCA-2 RC-16 cut sheet.pdf
RC-16 Remote Volume Control - Oxmoor Professional Audio Products
But there are certainly much more offers.
Who can post more URL's ??
Remote controlled Attenuators - Basics:
http://www.weiss-highend.ch/computerplayback/Digital_Level_Control.pdf
http://electroschematics.com/wp-content/uploads/2010/01/digital-volume-control.gif
http://www.free-circuit-diagrams.com/projects/10/bigs/cir44.jpg
rangkaian digital volume
H-Bridge DC Motor Schematic - Robot Room
Constant impedance relay-resistor logarithmic attenuator
Hi-Fi Preamp - Analogue Research
only a bit better.
Volume control
DIYCLUB
DIYCLUB
more kits:
DIYCLUB
The VolControl, Volume/attenuator control board (Number 3)
about
http://electronics.dantimax.dk/Kits/Control_boards/index.html
and TentLabs Volume control (Number 5)
about
Volume control
must be in category B, because there are no potentiometer is in use; the device looks like a pot is an encoder (double rotary switch)
http://www.soselectronic.com/a_info/img_data/a/enkodery/70226.jpg
http://docs-europe.electrocomponents.com/webdocs/0124/0900766b8012457e.pdf
Alps | Passive Bauelemente | Widerstände | Trimmer, Potentiometer und Rheostate | Encoder |EC11B152420G
OMRON G6K SMD-Relais
http://www.fa.omron.co.jp/product/family/2847/index_p.html
http://www.datasheetarchive.com/G6K-2F-Y-datasheet.html
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=searchProducts&searchTerm=365-0377
http://de.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=3650377
about
about
Volume control
No news?Digital Potentiometer
Hello
this thing could be interesting to control a motorized potentiometer as ALPS or Panasonic Infrared Remote Decoder Module Power/Volume/light Contr | eBay
But I have difficulties to see how to use it to control a motor, any idea ?
Pascal
Pascal
I bought this one off eBay and it's junk: ALPS IR Remote Volume Control DIY Kit (100K)_Volume Control_Accessories Kit_Analog Metric Limited - DIY Audio Kit
The H-bridge is awful, it crowbars the rails until the MCU boots. The transistors are not saturated and the motor gets about 3.5V so it's ssslow.
I'm building a relay-based log attenuator with IR remote, as everything is multi-channel now.
Very interesting, also the other devices - thank you therefore.There is bentaudio.com that you can look at.
BentAudio.com :: TAP
What could be therefore the reason? Can you order and post the pdf schematic diagram ?? Then you certainly will get several advices from the members here to remove this not satisfy operating behaviour.I bought this one off eBay and it's junk: ALPS IR Remote Volume Control DIY Kit (100K)_Volume Control_Accessories Kit_Analog Metric Limited - DIY Audio Kit
Exactly knowledge of the appropriate bus requirements (SPI Interfaces) are necessary. Where are the associated basic describtions to find? Thank you for calling some URLs and threads here on diyaudio in this case.Hello
Pascal
Hello
Pascal
Hello
I think I found the easy solution. With this module L298N Dual Stepper Motor Driver Controller Board Module en vente sur eBay.fr (fin le 12-août-11 18:36:05 Paris) we can control motor rotary in both directions.
If I don't make mistake We have just to join :
D0 (PIN6) of IR controller to IN1 (PIN5) of Motor Controller
D1 (PIN5) of IR controller to IN2 (PIN7) of Motor Controller
ACT (PIN3) of IR controller to ENA (PIN6) of Motor Controller
Motor B+ PSU to VIN (PIN4)
5V PSU to +5V (PIN1) of IR controller and to +5V (PIN9) of Motor Controller
Ground to GND (PIN8) of IR controller and to GND (PIN8) of Motor Controller
Ground of 5V PSU and Ground of Motor B+ PSU
If we push on ">> Up" on remote control we have D0=5V, D1=0V and the polarity to have a rotation of the volume pot in direction to up volume
If we push on "<< Down" on remote control we have D0=0V, D1=5V and the polarity to have a rotation of the volume pot in direction to down volume
I have IR controller and Remote control, I will order Motor controller to finalise my project
Cordially
Pascal
The alps pot requires 5V and about 200 mA to run. It is best driven from two small change-over relays because if driving transistors are not driven to saturation the volt-drop is large and the motor will turn very slowly.
It is simple and cheap to do if you already have a remote controller with two outputs UP and DOWN
follow threads here of interest:
http://www.diyaudio.com/forums/solid-state/127997-solid-state-volume-controls.html
http://www.diyaudio.com/forums/anal...n-noise-digitally-controlled-volume-chip.html
http://gilmore2.chem.northwestern.edu/ubb/showpage.php?fnum=3&tid=4325&fpage=3
http://www.diyaudio.com/forums/solid-state/342-national-lm-1972-a.html
http://www.diyaudio.com/forums/solid-state/19350-pga2310-output-buffer.html
http://www.diyaudio.com/forums/digital-source/34122-new-digital-pre-amp.html
Hello
I finished to test, with this two modules Infrared Remote Decoder Module Power/Volume/light Contr | eBay and L298N Dual Stepper Motor Driver Controller Board Module en vente sur eBay.fr (fin le 11-sept.-11 18:36:05 Paris) you just need a good 9V 1A transformer and a PSU with two LM7805 (one for motor and one for modules)
It work perfectly
Pascal
It work perfectly
Pascal
Hello
It work perfectly
Pascal
Hi pascall, can you show any photo's or schematics of this setup please?
I'm looking for the 'simplest' motorised volume controller I can get and it's hard to find.!
Cheers
Lee
Pascal ? Where did you go ? I'm interested too. I don't mind walking over to the rack to turn on the amp; I don't mind walking over to switch the input. I don't need mute; I can just turn it down but I do want remote volume control.
If I have a clean amp and DAC source I do not want PGA2311 in the middle. I want to use LDR volume with 100K log pot but want to control the pot from my chair.
So for a more current BOM :
L298N Dual Stepper Motor Driver Controller Board Module 5V $6.69usd
L298N Dual Stepper Motor Driver Controller Board Module 5V For Robot Smart Car | eBay
Infrared Remote Decoder Module Power/Volume with remote handset $14.00usd
Infrared Remote Decoder Modul + Small 7-key Controller | eBay
ALPS Blue Velvet - STEREO Conductive Plastic Potentiometer, 100K, Motorized, audio/log taper volume control for LDR users $34.95
http://www.partsconnexion.com/product7383.html
5V regulated PSU , case, knob and interconnects
... am I missing anything ?
I want to replace a RC motor controlled volume control with an Alps,
I have found this auction:
Upgrade PGA2311 Stero Remote Volume Controller Preamp | eBay
unfortunately there is in use additional an RC input select.
Are there such kits without input select section ??
follow Versions without input selector I have found:
OMNITRONIC LH-125 IR-Attenuator
Steinigke Showtechnic GmbH | LH-125 IR-Lautstärkeregler | Online Plattform
Omnitronic LH 125 IR Lautstärkeregler | eBay
Vellemann MK-164
Velleman-Bausätze
Velleman nv - Item - Details - MK164
Vellemann MK-163
Velleman MK163 IR volume control from Conrad Electronic UK
Which kind of ICs are in use - standart or programmable versions?
Vellemann MK-164
Velleman-Bausätze
Vellemann MK-163
Vellemann MK-164
Velleman-Bausätze
Vellemann MK-163
Check out this thread
http://www.diyaudio.com/forums/anal...control-kits-overview-wanted.html#post4253266
- Design & Build
- Parts
- Infrared Remote Contr. Stepped Attenuator for Replacing RC Motor Volume Contr.Alps
