Industrial SMD Gainclone - group buy
Hi peranders,
I'm still working on my SMD Gainclone design, too (no buffer, but regulated supply!).
Can you just explain why you're using sets of MUR3020 and MUR820 in parallel?
Oh, and what board size do you plan to achieve?
Sebastian.
New specifications:
* 50 um pcb with groundplane
* Rectifier diodes, TO247 and option for TO220
* 4700 uF/50V max, 10 mm snap-in and regular ones too.
* LM3886, inverting, 1k+18k, properly decoupled
* Mute
* Output filter, 1.5 mm wire, 5 mohms, 0.7 uH
* Zobel network
* DC-servo, AD8620, properly decoupled (possible not to use it)
* Input buffer, non-inverting, 220 kohms input impedance, AD8620, properly decoupled.
* LM317/337 in SOT223
* All elctrolytic caps hole mounted
* SMD caps PPS, X7R, NPO types, 0805, 1206, 2220 size
* SMD resistors, 0805
* Lug connectors with option for 2.5 mm2 wires
* Fuses 5 x 20 mm
The goal is a complete product, just add two windings with AC, signal in and speaker out and a cute small pcb.
Ah, I see. I usually place the component symbols overlapping, so that they appear as single in the schematic but make all neccessary pins/pads available on the board. ;)
Due to the layout software I use, a rough 80mm x 100mm is where I start. :D
I would expect the components in your schematic to need not more than 3" by 2" including wide supply and gound traces.
But finally, the industrial smd GC will have to compare with the available (non-smd, unbuffered) boards, and those are small already...
I'm looking forward to see your results. :cool:
edit: Although I'm making own boards, I'm still interrested in your alpha/beta testing. At last, I want to use the smaller and better boards, not neccessarily the ones that come out first .And I need a lot of them, too... ;)
When I have alternative parts I can do it in two ways, Make more holes in one part or just add the second one. The advantage of the later is that you will get the shape (and polarity, important when it comes to diodes) of if and also get those in the parts lists. My software has a totally integrated database.
If you feel that you are up to building and testing drop me a note when I have the boards.
i find that the 3-pad "SOT" small signal diodes are easier to place than the 2-pad variety -- probably doesnt matter that much as they are just there to protect the servo and would probably be mounted correctly -- the 3-pad variety would assure that the protection diodes are oriented correctly.
it looks like a very nice project
jackinnj said:
Peranders --
You have 5 2R2 resistors in the output low pass filter -- the primary reason for using a 2 watt version in the through-hole version is to mount the wire used in the 0.7 uH coil --
The typical 10 ohms resistor's main purpose is infact to kill any oscillations due to the "L" and the "C"'s involved. The inductor I have in mind is made of 1.5 mm wire! My inductor is a bit "more" than normal, only 5 mohms!
The silk print
Component side
Solder side
Ground plane on solderside. Power ground to the left and signal ground to the right. The rectifier bridges don't have a ground plane.
Size 4" wide and 4.3" high
Per: one of the folks at Stereophile modeled the RLC of a real-world speaker with cables -- I used this when modeling the GC's that I use -- I found that the only effect of the resistor value was to change the Q of the coil.
peranders said:
I have written a circuit description see link. Remember that this page is in a frame (no navigation).
http://home.swipnet.se/~w-50719/hifi/qrp02/schema_qrp02.html
From this worm's eye-view the PCB's look good -- have you checked them with a Gerber-Viewer ? I doubt there are any errors, but it's worth the time investment.
