As a theoretical question:
What are the disadvantages, if any, of using matched impedances between stages when factors such as parasitic capacitance or inductance are negligible?
For example - if a tube gain stage has a 600ohm output Z and is driving a 600ohm input Z of a solid-state stage, where the SS stage does not have a Miller capacitance and there is no long cable to add capacitance, then I can only see two potential problem areas:
1) we "lose" half of the gain of the tube stage as a result of the power transfer characteristic of the 1:1 Z
2) if the stages are capacitively coupled then the capacitor must be quite large in order for us not to lose bandwidth in the low bass driving the 600ohm input
What happens to the high frequency bandwidth? If the stages are transformer coupled, then bandwidth degradation is solely dependent on the xformer itself, right?
What would be the advantages, if any, of lowering the output Z of the preceding stage to 60ohm, following the 10x rule?
Is the 10x rule predicated solely on getting 90% power transfer and easing capacitance issues, driving cables, etc.?
SY,
Thanks for the quick reply. This is the kind of clue I'm looking for - but do you really mean:
-*TUBE based*- "voltage amplifier stages perform best when the load is as high as possible" ???
This is the kind of thing throwing me - matched impedances are regularly used with digital, RF applications, etc. and distortion problems are never mentioned. So are you specifically saying that *tube* circuits have trouble with low impedances? Or would the same hold for a SS circuit with 600ohm output Z- distortion problems?
If we ramp up the theoretical model 10 times, using 6000:6000ohm as an example, what are the implications?
Well, you posted this in the tube forum so I kinda assumed.
RF apps are different. Generally tuned stuff and more concerned with getting maximum power transfer than linearity. After all, we make class B and C transmitters, right?
In digital, impedance matching is important from the standpoint of reflections; this is not an issue at audio frequencies. And linearity is not a big deal when you're just switching on and off.
Well, you're right, i did post this in the tube forum! So, back to tubes - IOW choosing a lighter load, 6000R, what if the output Z of the preceding tube stage is also 6000ohm? Is the 1:1 Z-ratio simply not copasetic when tubes are involved?
Or, isn't there tube-based studio gear out there, even if it is transformer-interfaced, running 600ohm inputs yet not relying on a step-down or impedance-matching xformer but a 1:1 xformer?
In general, no. It's a complex thing, many books have been written on the subject, but I can give you 95% of it while standing on one leg:
Assume a triode. The equivalent circuit for an undegenerated triode with a plate load resistor looks like a voltage source in series with the plate resistance, rp, in series with the load resistance, RL. The output is taken across the load resistance, so you end up with something that looks like the voltage source with a divider across it. Clearly, the output is proportional to RL/(RL + rp), with mu being the coefficient.
Now, RL is fixed. On the other hand, rp is a function of the tube, it's the slope of plate voltage versus plate current. It varies quite strongly with plate current. So as the plate current swings, so does rp and thus the divider equation becomes non-linear. The lower the load, the more the required current swing and the greater the (variable) rp contribution to the transfer function. Double whammy.
As RL gets much bigger than rp, not only does the gain get higher, but the divider ratio tends toward unity, i.e., the tube runs more linearly.
Whew, let me put my foot back down.
Maximum power transfer occurs with matched impedance - you want this with power output stages and extremely low signal levels (to minimize noise). Voltage amplifier stages will be optimized for different parameters - maximum voltage swing, lowest distortion. This is true regardless of the type of active device. We aren't concerned with the efficiency of power transfer in a voltage amplifier stage - it's near zero.
A cathode follower (or emitter follower or source follower...) with an output impedance of 600 Ohms can't deliver a large voltage swing at low distortion into 600 Ohms. It can drive a high impedance load with significant capacitance or a cable.
The 10X "rule" is a good way to assure that the load isn't affecting the source characteristics (which is specified as a voltage output after all).
Here are some things to consider about the 600 ohm system...
It is balanced, therefore it's common-mode noise rejection is significiant in audio.... The common return and the shield are seperate unlike typical single ended, this is important..
The lower Z allows longer cable runs...with signifantly less loss than the typical single ended.....
Chris
Chris
consider voltage output ability and current output ability separately.
If your output stage can deliver 20Vac (~=60Vpp=30Vpk) then can it deliver that voltage into a 100k load?
This is where output current comes into the equation.
Iout=Vout/Iload eg, 20Vac =30Vpk.
Ioutpk=30/100k=0.3mApk. Is the output stage capable of delivering 30Vpk AND 0.3mApk.
Now change the load to 10k.
The output stage must now be capable of delivering 30Vpk AND 2.83mApk.
Now, put in 600ohm as your load.
Is the output stage capable of delivering 30Vpk AND 25mApk. I suspect not.
It is often instructive to look at both voltage and current (separately) in many circuits, even SS and input circuits.
RF is different than audio. What's essential for one can be bad for the other. Just a couple of thoughts:
In an RF circuit, the output of one stage can be several cycles out of sync with the input of the next. The speed of light is slow in these circuits. We have to worry about reflections and extremely large losses in connecting stages.
I build RF semirigid cable assemblies from time to time and 3dB is pretty respectable for longer runs (3-4 feet) at 18GHz. (You don't want to know how bad losses are in flexible cables.) That's burning half my power in a short little cable. If I didn't maximize my power transfer to the load there would be no power left at the end. Thank goodness we don't have to worry about this at lower frequencies.
- Tubes / Valves
- Impedance, the 10x rule, losses & bandwidth
