Namely I need help in making sure I'm doing just 3 things correct... I have the BrianGT boards
I have all the resistors for output matching etc etc
3 questions.... any thing helpful would be great
1. The OG from each board (in pairs of 2 paralleled per channel) is the Output ground so I assume I parallel these to the - terminal of the output banana jacks?
2. The AC1 and AC2 one has a line over it the other doesn't... I'm assuming the line over it means neutral correct?
MOST IMPORTANT QUESTION:
3. I have a transformer with dual primaries and secondaries... I understand perfectly that the dual secondaries are split to each board etc (one for the AC1 other for the AC2) ... but with dual primaries to I need to hook both primaries to the 115V AC? or will just one suffice? they can both be on the same AC jack correct?
thanks in advance
I'll post pics of this in a few hrs
thanks in advance
maf_au said:
I've read that... about 20 times... they don't ever go into the line over the AC.. cause on the other boards it actually says H and N (hot and neutral)
also it talks nothing about dual primaries and how to wire that up properly...
thanks though
Hmm.
Well, one thing you could do would be to connect one of the primaries and see what the secondary voltages look like.
I would think that you need to connect both primaries though, but I'm no expert. What does the transformer datasheet say?
Personally, I wouldn't tinker with it until you know the facts, mains voltage is dangerous...
maf_au said:Hmm.
I don't have a xfrmr sheet... there's just a diagram of the wiring
I'm assuming both need to be hooked up
GeWa said:Hi Audiophilenoob
If you have 115V mains you connect "BOTH" primary windings PARALLEL to your power socket. If you have 230V mains you connect "BOTH" primary windings in SERIES to your power socket.
Cheers
thanks very much... this is what I was assuming
WHat he said....
Got my vote. Hey are you pulling off a parallel amp for you ribbon?
Mark
Mark
Re: WHat he said....
well it's for the ribbon... but I'm employing a transformer for 4/2 ohms...
I'm unsure which right now
Mark
- Chip Amps
- I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :)
