That is one of the great myths of loudspeakers.
Of course electrical damping is happening and the amplifier source impedance (in conjunction with the voice coil DCR) determines how much electrical drag is exerted and so determines the system Q. But... in the end it is all fully covered if you view it as simply how flat are the electrical volts at the woofer and how does this change if the amplifier source impedance changes. The answer to that comes from looking at the woofer impedance curve.
If the amplifier source impedance rises (DF falls) you tend towards more constant current and the woofer drive voltage looks less flat and more and more like its impedance curve. That is, the woofer's normal response under low Z, high DF drive gets equalized by the impedance curve (or some proportion of the impedance curve) as source impedance rises. The calculations I did were just a shorthand look at how the lowest and highest points of the impedance curve would perturb the frequency response with the given 0.8 ohm source impedance.
If you think about woofer "damping" you will tend to get confused. The variation in driving volts due to source impedance is whats really going on.
David
Yeah, a lot of these things I don't have a perfect grasp on. I'm re-reading what you've written and it does make sense. I had always thought about it as higher numbers, up to a point were responsible for "pulse response linearity" I guess is the right way to say it.
Is there another word for that, or is that essentially a non issue at all? Or is it completely dictated by driver parameters?
Last July, a friend of mine on another forum posted this explanation:
Best Regards,
TerryO
Let's do some math.
We know that damping factor is a ratio, specifically, it's the load impedance divided by the output impedance of the amplifier. For now, we'll ignore how amplifiers attain low output impedance just for the sake of simplicity.
So, let's say we have an amplifier with a damping factor of 2000 and an impedance of 8 ohms.
DF = Load Impedance / Output Impedance
2000 = 8 / Output Impedance
Output Impedance = .004
All is well in the world, right? We have our staggeringly high damping factor but we've ignored something important.
We forgot to include the series resistance of the speaker wire between the amp and speakers. Let's redo the calculation now.
Again, we know that DF = Load Impedance / Output Impedance, but now we are going to add in the effects of the speaker wire into our equation to figure out what the "real" or "effective" damping factor is of the real world situation. For simplicity sake, we'll err on the side of caution and say that it's very low resistance wire and only presents a .1 ohm load.
DF = 8 ohm / (.004 ohm + .100 ohm)
DF= 8 ohm / .104
DF= 76.9
The advertised damping factor of 2000 is now only 77 at the terminals of the speakers.
Now, let's look at what is going on at the terminals of the woofer in a speaker system with a passive crossover.
It's not unusual to have a series resistance of 1 ohm in a passive crossover, but just for a best case scenario, let's say that it's only .25 ohm.
DF = 8 / (.004 + .100 + .250)
DF = 8 / (.354)
DF = 22.6 at the woofer.
Now, let's say the damping factor of the amp is 20000! Surely that must make a huge difference being an order of magnitude higher than 2000!
Unfortunately, the reality is:
DF = 8 / (.0004 + .25 + .1)
DF = 22.8
It's essentially the same.
Now, let's say that the amplifier in the same scenario is only at 50.
DF = 8 / Output impedance
50 = 8 / Output Impedance
Output Impedance = .16
Now that we have the output impedance of the amp with a DF of 50, let's subsitute into our scenario to see the DF at the woofer:
DF = 8 / (.16 + 1 + .25)
DF = 8 / (.51)
DF = 15.7
Do you see how most people just don't find DF that important? In the real world, the difference between a low DF amp and a ridiculously high DF amp is essentially moot at the woofer.
Best Regards,
TerryO
Lets stick with sealed boxes (2nd order systems) to keep things simple. There is a total system Q that is a combination of the mechanical damping factors (such as loss in the surround or loss in the cabinet stuffing) and electrical damping factors.
We refer to the system Q's they create as Qm and Qe. Generally we want Qe to be low and Qm (mechanical) to be high because that gives us a little higher sensitivity, that is we want the majority of our damping to be electrical. In the end there is a total Q from the parallel combination of the two. If we want flattest response to resonance then we will shoot for a Q total of .7 (2nd order systems only! 4th order systems need two different Qs).
Usually for Qe (electrical Q) we assume a best case of zero output impedance driving the woofer, but if we have nonzero source impedance then the electrical Q will rise. Note that DC resistance of the voice coil is in the mix also. Even with infinite amplifier damping we only have so much effective damping because DCR gets in the way. This is another way to understand why extremly high damping factors don't do much: even with dropping the amplifier Z to zero (infinite damping) you will still have the DCR in the mix preventing infinite damping.
There is an impulse response or step response associated with any 2nd order system of a given Q. Generally low ringing is a good thing when we view impulse response, and yes, lower Q will give lower ringing. The trouble is that improving the impulse ringing comes at the expense of damping out the bass. You could have a system with a Qt of 0.1, and its impulse would be wonderfully well damped, but it would have no bass!
Thats my only problem with the Wikipedia quote, that they imply more damping means a better impulse response ("tight control") and that more is always better. In fact there is an optimum Q, and an optimum bass response that comes from that Q and therefore an inevitable amount of ringing that also comes along with that Q.
Hope it all makes sense,
David
p.s. TerryO, good quote.
I'm a little thick when it comes to math, but I'm trying!
There is more in the article that goes on to say that after a DF of about 50 or so, it really doesn't make much difference. There's also some mention of older amplifiers that have selectable damping, like 1/5/50.
What you say makes sense though. I'm taking away that there should be a magic number that tends to work well?
The problem with the magic number is that all other factors would have to be known, that is cables, crossover, drivers. This is a bit unrealistic other than a situation with an active speaker, and these have a hard time selling to a larger market.
Best Regards,
TerryO
David
It's from a former "Bass List" member which carries a certain crediabilty all by itself!
Your explainations are quite good as well.
I have to admit that I once believed in the "The Iron Grip of Control that a high damping factor gives", but sadly had to abandon that notion some years ago, when faced by reality.
It was like losing an old, familiar friend.
Best Regards,
TerryO
Kinda like when you suddenly realize as a child that there's no way 300lb philanthropist in fluffy red clothes could ever fit down your chimney?
haha.
haha.
WHAT?
You're just kidding, right?
Not me, a good compression horn has a Qt around 0.1 and why I have been and will always be a 'hornie'.............
GM
From the very person that started me wondering about how this all tied together!
Hi Greg!
Best Regards,
Terry
My take on what Speaker Dave above has said is DF is a bogus concept. What IS of concern is the Q of the matching of an amplifier and loudspeaker system. Source impedance of the amplifier is important in terms of the extent to which it does or doesn't push Q of the amp/ speaker system outside what the designer would consider to be a desirable range.
I do realize that I'm discussing only one side of the two sides that Speaker Dave points to as being affected by source resistance of the power amplifier.
-Pete
-Pete
Ok, TerryO is no longer "World's Worst Mathematician" that title now goes to DrDyna, Congrats
You just take that back Mister!
Nobody, and I mean nobody, comes close to my level of mathematical inability!
Dr.Dyna? Ha! Not even close.
LOL!
<3
FWIW wiring two drivers in series increases the damping factor for directly
driven drivers. In practice how high the DF is, is limited by inductor DCR.
But if DF is low due to significant amplifier resistance, series will up it.
Also FWIW series wired drivers can (not always do) have some weird
problems approaching the excursion limits due to interactions between
the coils that don't happen is parallel.
for transistor amps the specced DF is pretty meaningless above around 20.
rgds, sreten.
rgds, sreten.
Hi Greg!
Best Regards,
Terry
Greets!
Yeah, what was that thread? 'Q for the Qless' or some-such. As already noted, it's all about getting the desired system Q and why for serious [by my standards] HIFI we need to get back to field coil drivers and variable DF electronics. Pass Labs F1/whatever type amps shouldn't be a budget buster if mass produced, though of course drivers would be more expensive in general.
Horns are finally making a bit of a comeback after a ~ 50 yr hiatus out in the deep fringe, so maybe Wild Burro's FC Betsy will jump start the next 'new thing'. Then again, the way the world's economy, [over] population is heading and the incredible advancement in DSP and materials technology in recent years it may not be too long before we're literally listening to talking pictures or even murals mounted on the walls...........
GM
rgds, sreten.
You'll only confuse them.
David
David
I'm not confused after our talk yesterday
I can hijack my own thread? Since so many gurus are on this thread... can you wire a 8 inch to a 6 inch with no crossover and let them work together the idea is that the six inch will naturally emphasize the higher and the 8 the lower.... the drivers from the same family? Don't beat me up... this is how we learn. I am thinking of an open baffle.
I suppose ,
it would depend on the drivers natural rolloff's, sensitivity, and... everything else. what drivers are you thinking about using?
- If wiring in series raises ohms why not parallel?
