75. Juancho 3 x RPI isolatorIan KIT Interesting List 2016:
1. StuderB67: 2x I2StoPCM
2. hopkins:1x S/PDIF interface board, 1x MC FIFO & MC XO
3. mk57:S/PDIF interface board
4. sckramer 2x RPi isolator boards
5. MikeyFresh: 2x RPi Isolator
6. Greg Stewart 3x RPi isolator boards
7. Ben Mah: 1x RPi Isolator
8. bigpandahk : I2S/DSD FIFO
9. brother c : 1x MC FIFO & MC XO, 1x Raspi/Odroid isolator
10. ernesternest: 1x RPi isolator
11. RollE2k: 1x RPI isolator
12. tracer5: 1. Raspberry Pi /ODROID I2S/DSD isolator HAT
13/ diyaudnut: 1x MC FIFO & MC XO
14. tsuntaro: 1x MC FIFO & MC XO
15. jonners: 2x RPi Isolators
16. Yatsushiro: 2x RPi Isolators
17. vzs: 1x RPi Isolators
18. clivem: 10x RPi Isolators
19. supra I2S/DSD FIFO KIT, Raspberry Pi /ODROID I2S/DSD isolator HAT
20. ed linssen: I2S to PCM board (1x), TPS7A4700 reg(or alike) (1x).
21. Morde: 1x RPi Isolator HAT board
22. curryking: 1x SPDIF interfaceboard,1x I2S Isolator,1x I2S FIFO II Kit
23. minio: 1x Rpi Isolator
24. number9 2 X RPI Isolators
25. Oyvind 2xRPI Isolators, dual clock board
26. bobsherman
27. pierantonio: 2 x RPi Isolator boards
28. BarG01: I2S to PCM board (1x), 6" double-ended silver plated U.FL coaxial cable (6x), Package of Universal SMT XO Adapters KIT lot of 5 ,
29. Josoeff: 1 x S/PDIF interface boar
30. superberg: I2S to PCM board (1x) + Raspberry Pi /ODROID I2S/DSD isolator HAT (1x)
31. larsth: 2x RPi isolator boards, 1x finished I2S FIFO board, 1x finished Dual XO Clock Board
32. savvas: I2S to PCM board
33. bommetje: 2x rpi isolator
34. minionas 1x RPI/ODROID isolator HAT; 1x S/PDIF Interface Board; 1x SMT finished Battery Management V2.5 Mini KIT; 5x SMT U.FL socket
35. percival007 (3X) I2S to PCM PCB
36. boulogne75: 2 x RPi/Odroid Isolator Boards
37. Blitz: 1x MC isolator+clock. BBB/Rpi isolatorx1
38. Abartels1965: 1x RPI/ODROID isolator HAT
39. Crom: 1 x FIFO DSD Kit & 1 x RPI isolator hat
40. hires: 1x MC FIFO + 1x MC XO board + 1x Rpi/Odroid isolator
41. mvagusta22: 1x FIFO Isolator and 1x Rpi/Ordoid isolator
42. xaled: 1x MC FIFO + 1x MC XO board + 2x Rpi/Odroid isolator + 1x I2S to PCM board
43. JimS: 1x MC FIFO, 1X MC XO
44. mjensen: 1 x MC FIFO, 1 x MC XO, 1 x RPI isolator
45. hileman65: 2x I2S to PCM, 4x TPS7A4700 reg, 6x 6" double ended U.FL coax cable
46. marcus1: 1 x R Pi/ODROID: I2S/DSD isolator HAT
47. Eldam : 1x low noise TS7A reg for Clock II + 1 x Odroid isolator HAT
48. rredline: 1x Rpi Isolator
49. rmpfyf: 1x MC FIFO, 1x MC XO, 1x I2S to PCM, 2x isolator
50. hpn5350: 1x RPi Isolator Board, 1x I2S FIFO II Kit, 1x Dual XO Clock Board, 1x I2S Isolator, 1x SPDIF Interface, 1x TPS7A4700 Regulator
51. Canvas: 1x MC FIFO, 1x MC XO, 2x I2S to PCM, 1x RPI isolator
52. franz159: interested in two Raspberry Pi I2S isolator HAT
53. trung224: 1x RPI/Odroid Isolator
54. duster1: 1x I2S/DSD FIFO, 1x XO, 1x RPI/Odroid isolator
55. kolossos4730 2x RPi Isolators
56. Flyingsparks: 1x MC FIFO, 1x MC XO, 2x RPi Isolator Board, 1x SPDIF Interface
57. tubesguy: RPi isolator
58. tods: 1x MC FIFO, 1x MC XO, 4x RPi Isolator Board
59. Brumjam: 1x stereo FIFO, 1x dual XO board with clocks, 1x finished isolator board, 1x SPDIF board, 1x low noise regulator board, 1 x pack of universal XO adapters, 1 x set of 6 double-ended UFL cables 6", 1 x standoff pack, 1 x Pi I2S cape adaptor PCB
60: Jp85: i2s to PCM board x1, rpi/odroid isolator x1, 1x set of 6 double-ended UFL cables 6"
61. Sidiropa: 1x MC FIFO, 1x MC XO
62. dorkus: 1x Raspberry Pi I2S isolator HAT
63. badboygolf16v: 3 x RPi Isolator, 1x I2S/DSD FIFO, 1x MC XO, 1 x SPDIF, 1x low noise regulator board, 1 x Pi I2S cape adapter (if available), 2 x CCHD 957 adapter board, 3 x SMT finished Battery Management V2.5 Mini KIT (if available)
64. audiopassion: 2x MC FIFO, 3x MC XO, 2x RPi Isolator Board
65. ChrisMmm: 2x RPi I2S isolator HAT
66. flowerpot 1x I2S/DSD FIFO, 1x Rpi/Odroid isolator, 1x I2StoPCM
67 ianrt 2 x RPi isolator HAT
68 malarkey 3 x RPi isolator HAT(bidirectional)
69 myint 67 1xrpi isolator hat ,1x I2s/dsd fifo ,1MCXO
70. lindamar: 1x MC FIFO & MC XO, 2x RPi/Odroid isolator
71. nautibuoy: 1x RPi Isolator HAT
72. bismuth: 1x RPi Isolator
73. Clemmaster: 2x RPi Isolator HAT (bidirectional), 1x I2S FIFO II Kit, 1x Dual XO Clock
74. Nikola Krivorov: 1x RPi Isolator, 1x I2StoPCM
26. bobsherman
76. nounouchet: 1x RPi Isolator HAT (bidirectional), 1x I2S FIFO II Kit, 1x Dual XO II Clock Board, 1x TPS7A4700 regulator
26. bobsherman
26. bobsherman
77. tecd: 1x I2S FIFO II board, 1x Dual XO II Clock Board 45/49 XOs, 1x I2S to PCM converter board, 1x Finished FIFO Isolator board, 1x Finished TPS7A4700 LDO regulator, 1x S/PDIF interfact board, 1x Battery Management PCB, 1x BIII adapter PCB, 1x Package of Universal SMT XO Adapters lot of 5, 4x Anti-vibration screw grommet set, 15x SMT U.FL socket, 3x 4” double-ended 50 ohm silver plated coaxial cable, 4x 6” double-ended 50 ohm silver plated coaxial cable
26. bobsherman
26. bobsherman
78. urien: 1x I2S FIFO II Kit, 1x I2S Isolator, 1x XO board, 1x I2S to PCM
26. bobsherman
26. bobsherman
79. ermine22: 2x MC FIFO, 2xMC XO, 4xRPI isolator
26. bobsherman
26. bobsherman
76. nounouchet: 1x RPi Isolator HAT (bidirectional), 1x I2S FIFO II Kit, 1x Dual XO II Clock Board, 1x TPS7A4700 regulator, 1x Package of Universal SMT XO Adapters KIT lot of 5
26. bobsherman
Update: Parts no longer required for marcus1 (position 46). Removed order.
26. bobsherman
46. marcus1: parts no longer required.
26. bobsherman
26. bobsherman
80. erikdebest: 2xRPI isolator
26. bobsherman
26. bobsherman
81. Stunts: 1x I2S/DSD FIFO, 1x I2S/DSD Isolator, 1x DSD Dual XO w/CCHD957 sockets and low noise regulator, 1x BIII adapter+connector, 1x RPi adapter cap
26. bobsherman
26. bobsherman
82. shochu: 1x RPi Isolator HAT (bidirectional)
26. bobsherman
26. bobsherman
82. shochu: 1x RPi I2S/DSD Isolator (version that works with kali+piano)
26. bobsherman
26. bobsherman
83. s3gfault: 1x RPi isolator
26. bobsherman
26. bobsherman
63. badboygolf16v: 3 x RPi Isolator, 1x I2S/DSD FIFO, 1x MC XO, 1 x SPDIF, 1x low noise regulator board, 1 x Pi I2S cape adapter (if available), 2 x CCHD 957 adapter board, 3 x SMT finished Battery Management V2.5 Mini KIT (if available), 1 x I2S to PCM
26. bobsherman
26. bobsherman
84. M_Balou: 1x RPI Isolator
26. bobsherman
26. bobsherman
Changed my setup and removed my entry (number 2). Hope it is not necessary to renumber the entire list...
26. bobsherman
26. bobsherman
85. Znarfomat: 1x Finished FIFO Isolator board, 1x RPi I2S isolator HAT
26. bobsherman
26. bobsherman
86. nielsek: 1x RPI Isolator
26. bobsherman
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
