1. jbercovici : 1x I2S FIFO KIT V3.80, 1x Package of Universal SMT XO Adapters lot of 5, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket,
2. Celihman : 1 pcs I2S FIFO KIT, 1 pcs Dual XO Clock board
3.
4. APK 1x FIFO KIT, 1x Si570 Clock board, 3x TPS7A4700 Regulator, 1x FIFO isolator, 3x Battery management 1 x s/pdif 1 x I2S backdoor plus
5. duster1 : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Finished FIFO Isolator, 1x Si570 Clock board with Si570, 2x Finished TPS7A4700 Regulator, 1x Battery management, 1x I2S backdoor, 1x SMT XO Adapters Kit
6. chi0001: bIII adapters pcb x4, tps7a4700 x4
7. hsi68 : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket, 4x 6” double-ended 50 ohm coaxial cable
8. malarkey : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 2x S/PDIF Interface Board, 1x Finished FIFO Isolator
9. mcluxun: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board
10. casshan : 4 x I2S FIFO KIT v3.8, 4 x Finished FIFO isolator board v2.5, 3 x Dual XO Clock board V3.3, 1 x Si570 Clock Board V3.5(with Si570), 1 x Finished TPS7A4700 low noise regulator board V2.5
11. hangguy: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board, 1x Finished TPS7A4700 low noise regulator board V2.5
12. luisbock
13. lxiaob
15 kazap: 1x i2s FIFO kitv3.80, 1 x PCM1704 board, 1x Dual XO Clock Board, 1x finished FIFO isolator board, 1x Finished TPS7A4700 low noise regulator board V2.5, 1x Battery management, 1 x S/PDIF Interface board, 1 x I2S backdoor KIT, 4x 6” double-ended 50 ohm coaxial cable, 1x Package of Universal SMT XO Adapters lot of 5, 10x SMT U.FL socket
16. iskwon: 2xI2S FIFO KIT and 2x Dual XO Clock board
17. audiopassion
18.ctrange: 1xI2S FIFO KIT V3.80, 1xDual XO Clock board V3.3, 4xSMT U.FL socket, 1x12” double-ended 50 ohm coaxial cable, 1x6” double-ended 50 ohm coaxial cable, 1xPackage of Universal SMT XO Adapters.
19: LOBOONE: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x Package of Universal SMT XO Adapters lot of 5, 1 x Additional BIII adapters PCB , 1 x SMT connector package for BIII adapters, 1 x 10P 1.0mm FFC/FPC cables combo, 1 x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 1 x Passive Battery Management Board V2.5 Mini KIT
20. errmoo I2S FIFO KIT V3.80, Si570 Clock Board V3.5(with Si570), S/PDIF Interface Board
21. sernikus I2S FIFO + Dual XO
22. TonyB: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface, Board, 1 x Package of Universal SMT XO Adapters, 1 x PCM1704 board, 1x I2S backdoor
23. korben69 : 3 x Bare PCB of TPS7A4700
24. Billyk: 14x SMT U.FL socket, 2x 6” double-ended 50 ohm coaxial cable, 4x 4” double-ended 50 ohm coaxial cable
25. pavelal: I2S FIFO KIT V3.80, Dual XO Clock board V3.3,S/PDIF Interface Board, 10 x SMT U.FL socket, 8 x 6” double-ended 50 ohm coaxial cable, 3 x 12” double-ended 50 ohm coaxial cable, Package of Universal SMT XO Adapters lot of 5, Finished FIFO isolator board V2.5, 2 x Finished TPS7A4700 low noise regulator board V2.5, Passive Battery Management Board V2.5 Mini KIT
26. JustBuildLspkAS: 2 sets with optimize SQ/ minimize board qty for TDA1541 and PCM1704/63
Like this
........26.1) PCM1704/63 =my usb interface xmos > i2s FIFO v3.80 assy board + Reclock assy board > my PCM1704s
........26.2) TDA1541=my usb interface xmos >i2s FIFO v xxxxassy board + Reclock assy board > my TDA1541s
27. crobbins5421: Dual XO Clock Board, Universal SMT XO Adapters lot of 5
28. Iancortez: 4 x SMT UFL socket, 2 x Additional BII adapter pcb, 2 x SMT connector package for BII adapters
29. LuisMCP: 4 x BIII Adapter PCB.
30. TNT: 1 FIFO board (no clock). 3x Finished TPS7A4700
31. clsidxxl :1x I2S FIFO KIT V3.80,1xDual XO Clock board V3.3,1x Package of Universal SMT XO Adapters,1x Finished FIFO isolator board V2.5,1x Finished TPS7A4700 low noise regulator board V2.5
32. Ryelands: 1 of I2S/FIFO kit; 1 of finished isolator board; 1 of Dual-XO Clock board; 2 of finished TPS7A4700 board; asstd cables.
33. jcga: 2 x TPS7A4700 finished boards; 3 x TPS7A4700 PCB only; 2 x passive Bat management minikit; 2 x U.FL socket kit; 1 x xoadaptator kit
34. canvas: 1 x I2S FIFO KIT V3.80, 1 x Dual XO Clock board V3.3, 1 x S/PDIF Interface Board
35. sidiropa:1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x Additional BIII adapters PCB , 1 x SMT connector package for BIII adapters, 1 x 10P 1.0mm FFC/FPC cables combo, 1 x Finished FIFO isolator board V2.5, 1 x Passive Battery Management Board V2.5 Mini KIT
36. hochopeper: 2 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 2 x finished FIFO isolator, 1 x Si570
37. zapio : 1 x Si570 , 2 x finished FIFO isolator
38.fregones : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1 x Si570
39. fukinspud : 1x finished I2S FIFO board, 1x finished Dual XO Clock Board, 1x finished S/PDIF Interface Board, 1x Finished FIFO Isolator, 1x finished Si570 Clock board with Si570, 2x Finished TPS7A4700 Regulator, 1xfinished Battery management, 1x finished I2S backdoor, 1x finished SMT XO Adapters Kit
40. nedi: 1x FIFO Kit v3.80, 1x Dual XO clock board v3.3, 1X Finished FIFO Isolator board v2.5, 1x S/PDIF interface board, 1x I2S backdoor kit for S/PDIF board, 1x Passive Battery management board v2.5 mini kit
41. manolo2001: 2x finished I2S FIFO board, 2x finished Dual XO Clock Board, 1x finished S/PDIF Interface Board, 2x Finished FIFO Isolator, 1x finished Si570 Clock board with Si570,1x Package of Universal SMT XO Adapters lot of 5, 2xFinished TPS7A4700 low noise regulator board V2.5, 10 x SMT U.FL socket, 10 x 4” double-ended 50 ohm coaxial cable, 6 x 6” double-ended 50 ohm coaxial cable
42. Peterma: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator
43. Tony_T: 1x I2S FIFO KIT V3.80, 1x 10P 1.0mm FFC/FPC cables combo, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 3x Finished TPS7A4700 low noise regulator board V2.5
44. Heffa: 1 x Package of Universal SMT XO Adapters lot of 5, 2 x Additional BIII adapters PCB, 2 x SMT connector package for BIII adapters, 4 x 4” double-ended 50 ohm coaxial cable
45. curryking 1 x Dual XOClock Board,2 X Package of Universal SMT XO Adapters Kit,1 x Si570 Clock Board V3.5(wuth Si570),1 x Finished TPS7A4700 low noise regulator board V2.5,
1 x SMT finished Battery Management V2.5 Mini Kit, 2 x 6" double-ended coaxial cable
46. vanwykca: 3 x additional BIII adaptor PCB, 3 x SMT connector package for BIII adaptors, 5 x finished TPS7A4700 low noise regulator board V2.5
47. Joonas: 1x fifo kit, 1x dual clock board, 1x spdif board, 1x finished isolator boards, 2x adapters for crystek if you still have them, 1x nos pcm add-on from the other thread
48. wl336: 1x fifo kit, 1x dual clock board, 2x adapters for crystek if you still have them
49. _oxygen: 1x I2S FIFO KIT V3.80, 1x Package of Universal SMT XO Adapters lot of 5, 1x Si570 Clock Board V3.5(with Si570), 2x Finished FIFO isolator board V2.5, 3x Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket, 1x 10P 1.0mm FFC/FPC cables combo, 1x Additional BIII adapters PCB, 1x
SMT connector package for BIII adapters, 10 x 4” double-ended 50 ohm coaxial cable, 6 x 6” double-ended 50 ohm coaxial cable
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
49. _oxygene: 1x FIFO Kit v3.80, 1x Si570 Clock Board V3.5(with Si570), 2x Finished FIFO isolator board V2.5, 3x Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket, 6x 4” double-ended 50 ohm coaxial cable, 4x 6” double-ended 50 ohm coaxial cable, 1x Package of Universal SMT XO Adapters lot of 5, 1x Additional BIII adapters PCB, 1x SMT connector package for BIII adapters, 1x 10P 1.0mm FFC/FPC cables combo
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
50. frd__: 10x Bare PCB of TPS7A4700 low noise regulator
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
51. palmito: 1 FIFO board
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
52. brettlb: 2 x FIFO board, 2 x Isolator board, 1 x Si570 with Si570, 4 x finished regulator boards.
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
53.davej: 1 x FIFO kit, 1 x dual XO, 1 x finished isolator board, 1 x finished TPS7A4700 regulator
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
54. flowerpot: 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
55. Bennyboyvg: 1 x FIFO board, 1 x Si570 board (with Si570), 1 x finished isolater board, 1 x finished regulator board, 1 x additional BIII adapters PCB's, 1 x SMT connector package, 6 x 4" coax cable, 7 x SMT U.FL socket
3.
12. luisbock
13. lxiaob
17. audiopassion
Like this
GBV I2S to PCM board waiting list
I move I2S to PCM board waiting list here from R&D thread:
http://www.diyaudio.com/forums/digi...rsal-i2s-pcm-driver-board-57.html#post3651924
This list is still open to new names.
PCM board and FIFO KIT are belong to different waiting list. I will run two list at same time on GBV.
Order number: ID and quantity
GBVPCM01 : TV Man x 2
GBVPCM02 : merlin el mago
GBVPCM03 : rtd
GBVPCM04 : jameshillj
GBVPCM05 : erin x1 (or 2)
GBVPCM06 : Nikola Krivorov x1
GBVPCM07 : Rupor54
GBVPCM08 : vitalica
GBVPCM09 : analog_sa x 1
GBVPCM10 : andrea_mori x 5
GBVPCM11 : dsavitsk
GBVPCM12 : tagheuer
GBVPCM13 : hirez69 x 2
GBVPCM14 : ccliu x 2
GBVPCM15 : BDL
GBVPCM16 : cddumat
GBVPCM17 : regal x 2
GBVPCM18 : zoran
GBVPCM19 : Jogi
GBVPCM20 : Zen(zenelectro) x 2
GBVPCM21 : Buzzforb
GBVPCM22 : SPWON
GBVPCM23 : crobbins5421 X 2
GBVPCM24 : marcus1 x1 (or 2)
GBVPCM25 : casshan x 2
GBVPCM26 : Dweeb99 X 2
GBVPCM27 : jackw X 2
GBVPCM28 : kazap X 2
GBVPCM29 : danzup x 3
GBVPCM30 : Giordano x2
GBVPCM31 : Tony_T
GBVPCM32 : Tubo x1
GBVPCM33 : clivem x2
GBVPCM34 : noizas x4
GBVPCM35 : JoeyDD x2
GBVPCM36 : skullaudio
GBVPCM37 : dinos8746 x2
GBVPCM38 : dvb-projekt
GBVPCM39 : bisesik x2
GBVPCM40 : guglielmope x1
GBVPCM41 : Valeriano x1
GBVPCM42 : mhgawel x1
GBVPCM43 : av-trouvaille x 1 (or 2)
GBVPCM44 : iloveswan x1
GBVPCM45 : dtses
GBVPCM46 : Flyboi X1
GBVPCM47 : Lil' Knight x1 (or 2)
GBVPCM48 : skippyboy x1
GBVPCM49 : acccruz x1 (or 2)
GBVPCM50 : WhiteBull x1
GBVPCM51 : hksidney x 1
GBVPCM52 : vts2006 x 3
GBVPCM53 : JustBuildLspkAS.x3 &1 fifo kit finished for pcm1704 (ihave AD1862 ,pcm63,pcm1704)
GBVPCM54 : 54: PET-240 2 * TDA1541
GBVPCM55 : TonyB
GBVPCM56 : damohpi x1
GBVPCM57 : iloveswan x 1
GBVPCM58 : Joseph K x 2
GBVPCM59 : mefistofelez x2 (pcm63P)
GBVPCM60 : JLOP x1 (WaveIO, AD1865 NOS SRPP)
GBVPCM61 : sceglar x1
GBVPCM62 : 4me2ctv x 1
GBVPCM63 : tubesguy x 1
GBVPCM64 : ctrange x 1
GBVPCM65 : spm x 1
GBVPCM66 : Joonas x1
GBVPCM67 : Loboone x 1
GBVPCM68 : flowerpot x 1
GBVPCM69 : pavelal x 1
GBVPCM70 : Steve Ha x 1
GBVPCM71 : new2hifi x 1
GBVPCM72 : Superdad x 1 (WaveIO, PCM1704K, discrete I/V)
GBVPCM73 : Greg Stewart x 1
GBVPCM74 : panther5429 x 1
GBVPCM75 : supra x 3
GBVPCM76 : Clsidxxl x 1
GBVPCM77 : Uchi Deshi x 1
GBVPCM78 : kvl x 1
GBVPCM79 : palmito x 1
GBVPCM80 : davej x 1
GBVPCM81 : crowlie x 1
GBVPCM82 : WhiteBull x2 (and one Dual XO Board, in case ones left)
GBVPCM83 : nedi x 1
GBVPCM84 : gonmar x 1
GBVPCM85 : LuisMCP x 1
GBVPCM86 : chansiukwing x 2
GBVPCM87 : tassosk x 1
GBVPCM88 : NATDBERG x 2 (NOS dual differential 2x D20400 project, NOS 384KHz TDA1541A project later)
GBVPCM89 : Jcastellano x1
GBVPCM90 : Marek x1
GBVPCM91 : SVStube x 3*
GBVPCM92 : mksung x 1*
GBVPCM93 : JimS x 2
GBVPCM94 : brettlb x 2
Ian
GBVPCM03 : rtd
GBVPCM07 : Rupor54
GBVPCM08 : vitalica
GBVPCM11 : dsavitsk
GBVPCM12 : tagheuer
GBVPCM15 : BDL
GBVPCM16 : cddumat
GBVPCM18 : zoran
GBVPCM19 : Jogi
GBVPCM21 : Buzzforb
GBVPCM22 : SPWON
GBVPCM31 : Tony_T
GBVPCM32 : Tubo x1
GBVPCM45 : dtses
GBVPCM55 : TonyB
GBVPCM65 : spm x 1
GBVPCM78 : kvl x 1
GBVPCM83 : nedi x 1
GBVPCM90 : Marek x1
GBVPCM93 : JimS x 2
Ian
GBV FIFO KIT waiting list 2013-10-01
Now I link the list with order number, please let me know for any problem.
GBVFIFO01 : jbercovici : 1x I2S FIFO KIT V3.80, 1x Package of Universal SMT XO Adapters lot of 5, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket,
GBVFIFO02 : Celihman : 1 pcs I2S FIFO KIT, 1 pcs Dual XO Clock board
GBVFIFO03 : APK 1x FIFO KIT, 1x Si570 Clock board, 3x TPS7A4700 Regulator, 1x FIFO isolator, 3x Battery management 1 x s/pdif 1 x I2S backdoor plus
GBVFIFO04 : duster1 : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Finished FIFO Isolator, 1x Si570 Clock board with Si570, 2x Finished TPS7A4700 Regulator, 1x Battery management, 1x I2S backdoor, 1x SMT XO Adapters Kit
GBVFIFO05 : chi0001: bIII adapters pcb x4, tps7a4700 x4
GBVFIFO06 : hsi68 : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket, 4x 6” double-ended 50 ohm coaxial cable
GBVFIFO07 : malarkey : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 2x S/PDIF Interface Board, 1x Finished FIFO Isolator
GBVFIFO08 : mcluxun: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board
GBVFIFO09 : casshan : 4 x I2S FIFO KIT v3.8, 4 x Finished FIFO isolator board v2.5, 3 x Dual XO Clock board V3.3, 1 x Si570 Clock Board V3.5(with Si570), 1 x Finished TPS7A4700 low noise regulator board V2.5
GBVFIFO10 : hangguy: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board, 1x Finished TPS7A4700 low noise regulator board V2.5
GBVFIFO11 : luisbock
GBVFIFO12 : kazap: 1x i2s FIFO kitv3.80, 1x Dual XO Clock Board, 1x finished isolator, 1x TPS7A4700, 1x Battery management, 1 x S/PDIF , 1 x I2S backdoor KIT, 4x 6” 50 coaxial cable, 1x XO Adapters, 10x SMT U.FL socket
GBVFIFO13 : iskwon: 2xI2S FIFO KIT and 2x Dual XO Clock board
GBVFIFO14 : audiopassion
GBVFIFO15 : ctrange: 1xI2S FIFO KIT V3.80, 1xDual XO Clock board V3.3, 4xSMT U.FL socket, 1x12” double-ended 50 ohm coaxial cable, 1x6” double-ended 50 ohm coaxial cable, 1xPackage of Universal SMT XO Adapters.
GBVFIFO16 : LOBOONE: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x Package of Universal SMT XO Adapters lot of 5, 1 x Additional BIII adapters PCB , 1 x SMT connector package for BIII adapters, 1 x 10P 1.0mm FFC/FPC cables combo, 1 x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 1 x Passive Battery Management Board V2.5 Mini KIT
GBVFIFO17 : errmoo I2S FIFO KIT V3.80, Si570 Clock Board V3.5(with Si570), S/PDIF Interface Board
GBVFIFO18 : sernikus I2S FIFO + Dual XO
GBVFIFO19 : TonyB: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface, Board, 1 x Package of Universal SMT XO Adapters, 1 x PCM1704 board, 1x I2S backdoor
GBVFIFO20 : korben69 : 3 x Bare PCB of TPS7A4700
GBVFIFO21 : Billyk: 14x SMT U.FL socket, 2x 6” double-ended 50 ohm coaxial cable, 4x 4” double-ended 50 ohm coaxial cable
GBVFIFO22 : pavelal: I2S FIFO KIT V3.80, Dual XO Clock board V3.3,S/PDIF Interface Board, 10 x SMT U.FL socket, 8 x 6” double-ended 50 ohm coaxial cable, 3 x 12” double-ended 50 ohm coaxial cable, Package of Universal SMT XO Adapters lot of 5, Finished FIFO isolator board V2.5, 2 x Finished TPS7A4700 low noise regulator board V2.5, Passive Battery Management Board V2.5 Mini KIT
GBVFIFO23 : JustBuildLspkAS: 2 sets with optimize SQ/ minimize board qty for TDA1541 and PCM1704/63
GBVFIFO24 : crobbins5421: Dual XO Clock Board, Universal SMT XO Adapters lot of 5
GBVFIFO25 : Iancortez: 4 x SMT UFL socket, 2 x Additional BII adapter pcb, 2 x SMT connector package for BII adapters
GBVFIFO26 : LuisMCP: 4 x BIII Adapter PCB.
GBVFIFO27 : TNT: 1 FIFO board (no clock). 3x Finished TPS7A4700
GBVFIFO28 : clsidxxl :1x I2S FIFO KIT V3.80,1xDual XO Clock board V3.3,1x Package of Universal SMT XO Adapters,1x Finished FIFO isolator board V2.5,1x Finished TPS7A4700 low noise regulator board V2.5
GBVFIFO29 : Ryelands: 1 of I2S/FIFO kit; 1 of finished isolator board; 1 of Dual-XO Clock board; 2 of finished TPS7A4700 board; asstd cables.
GBVFIFO30 : jcga: 2 x TPS7A4700 finished boards; 3 x TPS7A4700 PCB only; 2 x passive Bat management minikit; 2 x U.FL socket kit; 1 x xoadaptator kit
GBVFIFO31 : canvas: 1 x I2S FIFO KIT V3.80, 1 x Dual XO Clock board V3.3, 1 x S/PDIF Interface Board
GBVFIFO32 : sidiropa:1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x Additional BIII adapters PCB , 1 x SMT connector package for BIII adapters, 1 x 10P 1.0mm FFC/FPC cables combo, 1 x Finished FIFO isolator board V2.5, 1 x Passive Battery Management Board V2.5 Mini KIT
GBVFIFO33 : hochopeper: 2 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 2 x finished FIFO isolator, 1 x Si570
GBVFIFO34 : zapio : 1 x Si570 , 2 x finished FIFO isolator
GBVFIFO35 : fregones : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1 x Si570
GBVFIFO36 : fukinspud : 1x finished I2S FIFO board, 1x finished Dual XO Clock Board, 1x finished S/PDIF Interface Board, 1x Finished FIFO Isolator, 1x finished Si570 Clock board with Si570, 2x Finished TPS7A4700 Regulator, 1xfinished Battery management, 1x finished I2S backdoor, 1x finished SMT XO Adapters Kit
GBVFIFO37 : nedi: 1x FIFO Kit v3.80, 1x Dual XO clock board v3.3, 1X Finished FIFO Isolator board v2.5, 1x S/PDIF interface board, 1x I2S backdoor kit for S/PDIF board, 1x Passive Battery management board v2.5 mini kit
GBVFIFO38 : manolo2001: 2x finished I2S FIFO board, 2x finished Dual XO Clock Board, 1x finished S/PDIF Interface Board, 2x Finished FIFO Isolator, 1x finished Si570 Clock board with Si570,1x Package of Universal SMT XO Adapters lot of 5, 2xFinished TPS7A4700 low noise regulator board V2.5, 10 x SMT U.FL socket, 10 x 4” double-ended 50 ohm coaxial cable, 6 x 6” double-ended 50 ohm coaxial cable
GBVFIFO39 : Peterma: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator
GBVFIFO40 : Tony_T: 1x I2S FIFO KIT V3.80, 1x 10P 1.0mm FFC/FPC cables combo, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 3x Finished TPS7A4700 low noise regulator board V2.5
GBVFIFO41 : Heffa: 1 x Package of Universal SMT XO Adapters lot of 5, 2 x Additional BIII adapters PCB, 2 x SMT connector package for BIII adapters, 4 x 4” double-ended 50 ohm coaxial cable
GBVFIFO42 : curryking 1 x Dual XOClock Board,2 X Package of Universal SMT XO Adapters Kit,1 x Si570 Clock Board V3.5(wuth Si570),1 x Finished TPS7A4700 low noise regulator board V2.5,1 x SMT finished Battery Management V2.5 Mini Kit, 2 x 6" double-ended coaxial cable
GBVFIFO43 : vanwykca: 3 x additional BIII adaptor PCB, 3 x SMT connector package for BIII adaptors, 5 x finished TPS7A4700 low noise regulator board V2.5
GBVFIFO44 : Joonas: 1x fifo kit, 1x dual clock board, 1x spdif board, 1x finished isolator boards, 2x adapters for crystek if you still have them, 1x nos pcm add-on from the other thread
GBVFIFO45 : wl336: 1x fifo kit, 1x dual clock board, 2x adapters for crystek if you still have them
GBVFIFO46 : _oxygene: 1x FIFO Kit v3.80, 1x Si570 Clock Board V3.5(with Si570), 2x Finished FIFO isolator board V2.5, 3x Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket, 6x 4” double-ended 50 ohm coaxial cable, 4x 6” double-ended 50 ohm coaxial cable, 1x Package of Universal SMT XO Adapters lot of 5, 1x Additional BIII adapters PCB, 1x SMT connector package for BIII adapters, 1x 10P 1.0mm FFC/FPC cables combo
GBVFIFO47 : frd__: 10x Bare PCB of TPS7A4700 low noise regulator
GBVFIFO48 : palmito: 1 FIFO board
GBVFIFO49 : brettlb: 2 x FIFO board, 2 x Isolator board, 1 x Si570 with Si570, 4 x finished regulator boards.
GBVFIFO50 : davej: 1 x FIFO kit, 1 x dual XO, 1 x finished isolator board, 1 x finished TPS7A4700 regulator
GBVFIFO51 : flowerpot: 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator
GBVFIFO52 : Bennyboyvg: 1 x FIFO board, 1 x Si570 board (with Si570), 1 x finished isolater board, 1 x finished regulator board, 1 x additional BIII adapters PCB's, 1 x SMT connector package, 6 x 4" coax cable, 7 x SMT U.FL socket
Ian
Ian
Dear Ian, please change my order
GBVFIFO09 : casshan : 4 x I2S FIFO KIT v3.8, 4 x Finished FIFO isolator board v2.5, 3 x Dual XO Clock board V3.3, 1 x Si570 Clock Board V3.5(with Si570), 1 x Finished TPS7A4700 low noise regulator board V2.5 to
1 x I2S FIFO KIT v3.8
2 x Finished FIFO isolator board v2.5
2 x Si570 Clock Board V3.5 (with Si570)
GBVFIFO09 : casshan : 1 x I2S FIFO KIT v3.8,2 x Finished FIFO isolator board v2.5,2 x Si570 Clock Board V3.5 (with Si570),2 x Finished TPS7A4700 low noise regulator board V2.5
Ian
Ian
I did.
Ian
If the list is still open, I would like to add my order.
GBVFIFO53 : Popolvar: 1 x FIFO board, 1 x dual XO
GBVFIFO54 : necplusultra: 1 fifo board,1 x Si570 board (with Si570), isolator board, 5 TPS7A4700 boards
GBVFIFO15 : ctrange: 1xI2S FIFO KIT V3.80, 1xDual XO Clock board V3.3, 4xSMT U.FL socket, 1x12” double-ended 50 ohm coaxial cable, 1x6” double-ended 50 ohm coaxial cable, 1xPackage of Universal SMT XO Adapters to
1xFIFO isolator board V1.5 MINI KIT
1x10P 1.0mm FFC/FPC cables combo (3 cables)
4xBare PCB of TPS7A4700 low noise regulator P18
Added to my order
GBVFIFO24 : crobbins5421: 1 x Finished FIFO board, 1 x Dual XO Clock Board, Universal SMT XO Adapters lot of 5
GBVFIFO20 : korben69 : 4 x Bare PCB of TPS7A4700
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
