Don't feel locked in if you signed up for a FifoPiMa, but later want to go with a Q7 at or near the end of GB2023 even though your officially posted for a FifoPiMA:
If you "change your mind", it shouldn't be a problem as stated. For example, I'm officially posted for a StationPi SMT but later on last minute I might go with a StationPi Pro. I might even tack on other products last minute that I have not conceived yet like a Receiver Pi Pro. Something I never officially posted.
Hopefully, Ian weighs in for confirmation on your use case.
I have no clue on the technicalities since I'm here only for the SPDIF Toslink use case (SPDIF HAT), but what helps I is comparison charts:
Since I need 5.6 frequency support, Q3 and Q7 are my only options by taking a quick glance at the comparison chart. Otherwise, I would have to study each Fifo* Manual.
*Note1: If you want to join this GB2023, Please just put your ID and items to the interesting list at the end of this thread so that I can reserve the GB products for you. Of course you have no problem to cancel your items if you change your mind later because it’s just an interesting list.
Hi
Here my wish list :
StationPi Pro*1, FiFoPiQ7*1,TransportPi AES*1, UCPureMKIII *1, ShieldPi PCB *1 (free)
Probably more, but it is not clear yet ...
Here my wish list :
Clocks?, (2) 5V for StationPi Pro? I recommend UcBalancer to pair with UcPure MKIII. It's not much more considering shipping costs is a sunk cost. UcBalancer is $40 - $4 discount then weigh that with shipping costs. The UcBalancer will make your Eatons much happier being balanced no matter 3.3V, 5V, 12V or 15.5V.
1. Iancanada SC-Pure 45/49*1, FifoPiQ7*1, UcPureMkIII*2, HdmiPiPro*1
2. casshan SC-Pure 45/49 * 1, HdmiPiPro * 1, UcBalancer KIT * 1
3. princeliebe SC-PURE 45/49*1
4. Ben Mah SC-Pure 45/49*1, FifoPiQ7*1, MonitorPi*1
5. WuBai SC-Pure 45/49*1, LinearPiMKIIDual*1, LinearPiMKIISolo*1
6. jiacheng SC-Pure 45/49*1, RFX OCXO*1, MonitorPiPro*1, UCbalancer KIT*2, PurePi*1, GPIO extender*2
7. pyflaw SC-Pure 45/49*1, TransportPi AES*1, FifoPi Q7*1, PurePi*1, UcConditioner 3.3V*1, MonitorPi*1
8. NeoTheOne SC-Pure 45/49*1, FifoPiQ7*1, UcPureMkIII*2, HdmiPiPro*1, UCbalancer KIT*4, PurePi*1, StationPi Pro*1, ShieldPi Pro/MKII*1, RFX OCXO 45.1584 / 49.1520 MHz, Adapter KIT, SquarePi KIT, MonitorPi Pro, StationPi PCB (free stuff)*1, Linear Pi Dual MkII *1, UcConditioner 5V *1, UCConditioner 3V *1, ReClockPi*1, TransportPiAES*1
9. zapio: SC-Pure 45/49 * 2, TransportPi AES * 1, OPA861 I/V *1
10. WladimirMXP: SC-Pure 22/24*1, FifoPi Q7*1
11. Hires: SC-Pure 22/24*1, UcPureMkIII*1, MonitorPiPro*1
12. BasoFF: SC-Pure 45/49*1, FifoPiQ7*1, TransportPi AES*1, MonitorPi*1
13. smooth dancer: SC-pure 22/24, UCbalancer kit (1)
14. khh:SC-pure 22/24, UCbalancer kit (1)
15. triode4 SC-Pure 45/49*1, UcPureMkIII*2, UCbalancer KIT*4, IsolatorPiII*1, ShieldPi Pro/MKII*1, RFX OCXO 45.1584 / 49.1520 MHz, Adapter KIT, SquarePi KIT, SC-Pure 22/24*1, StationPi PCB (free stuff)*1
16. puuchan SC-Pure 45/49*1, FifoPiQ7*1, TransportPi AES*1
17. skilion51 SC-Pure 45/49*2, UCbalancer KIT*2, MonitorPiPro*1
18. wlowes SC-Pure 49
19. shoom SC-Pure 45/49*1
20. mikeh2022 SC-PURE 45/49*1, UCbalancer KIT*5, UcConditioner 5v*1, GpioSpacer*1, LinearPi Standoff/Screw Sets*2
21. Shutdown98 SC-Pure 45/49*1, FifoPiQ7*1, TransportPi AES*1
22. Trial and Error SC-pure 45/49*2, FifoPiQ7*1
23. secanbj SC-PURE 45.1584 / 49.1520 MHz x 1
24. SimonJ SC-Pure 45/49*1, UcBalancer KIT*2, MonitorPiPro*1, StationPi PCB (free stuff)*1
25. leviandrose SC-Pure 45/49*1
26. SelektaM SC-Pure 45/49*1
27. walangalam SC-Pure 45/49*1, FifoPi Q7*1, PurePi*1, StationPi PCB (free stuff)*1
28. jims SC-Pure 45/49*1, RFX OCXO*1, MonitorPiPro*1,
29. Canvas SC-Pure 45/49*1
30. Tubo SC-Pure 45/49*1, UCpure mkIII*1
31. AirAir: TransportPi AES*1, UCbalancer KIT*1, UcConditionerMkII 5V, UcConditionerMkII 3.3V, GPIO spacer
32. Photochum1: SC-Pure 45/49*1, FifoPiQ7*1, StationPiPro*1, HdmiPiPro*1, MonitorPiPro*1
33. chi0001 SC-Pure 45/49*1, FifoPiQ7*1, UcPureMkIII*2, UCbalancer(#41F)*2, HdmiPiPro*1, StationPi PCB (free stuff)*1
34. alecm SC-Pure 45/49*1, FifoPiQ7*1, GPIO extender, HdmiPiPro*1, MonitorPiPro*1, StationPi PCB (free stuff)*1
35. mvaldes SC-Pure 45/49*1, FifoPiQ7*1
36. jrocker SC-Pure 45/49*2
37. stew1234 SC-Pure 22/24*1, UcBalancer KIT*2, HdmiPiPro*1, UcPureMkIII*1, 9038Q2 DAC HAT*1
38. sazzz SC-Pure 45*1, HdmiPiPro*1, GPIO extender, StationPi PCB (free stuff)*1, UcPureMkIII*1
39. Sgaga Sc-pure 22/24*1
40. bisesik SC-Pure 45/49*1
41. spev SC-Pure 45/49*1, MonitorPiPro*2
42. sernikus SC-Pure 45/91*1 MonitorPiPro*1
43. topicreader SC-Pure 45/49*1, FifoPiQ7*1, MonitorPiPro*1, GPIO extender
44. BogdanS SC-Pure 45*1
45.Steef SC-Pure 45/49*1, FifoPiQ7*1, UcPureMkIII*2, UCbalancer KIT*2, TransportPi AES*1
46.KVL: SC-Pure 45/49*2, FifoPiQ7*2, UcPureMkIII*2, UCbalancer KIT*2, MonitorPi Pro*2, ShieldPi Pro MkII*1.
47. sugden : TransportPi AES *1, FifoPi Q7 *1, PurePi *1, UcConditioner 3.3V *1, MonitorPi *1, SC-PURE 45.1584MHz/49.1520MHz *1, StationPi PCB(free stuff)*1, GPIO spacer*1.
48. mvp: SC-Pure 45/49*1
49. danielu: SC-Pure 45/49*1
50. wcwc: SC-Pure 45/49*1, ConditionerPi*1, LinearPi MKII Dual*1, StationPi PCB (free stuff)*1
51. onepiece01 : SC-Pure 45/49*4
52. drone: SC-Pure 45/49*1,FifoPi Q7 *1, PurePi *1,MonitorPiPro*1,MonitorPi*1,UCbalancer KIT*2,HdmiPiPro*1,shieldPi Pro/MKII*1,OPA861 I/V *1,UCPureMKIII*1,StationPi PCB*1
53. "Drive Shaft": "#35C. StationPi SMT fully finished*1", "StationPi PCB (free stuff)*1"
54. Gabster2000 SC-Pure 45/49*1 StationPi PCB (free stuff)*1
55. Spartacus SC-Pure 45/49*1
56. stephen1212b SC-Pure 22/24 *1 SC Pure 45/49*1
57. MMatt1234: SC-Pure 45/49*1 FiFoPiQ7*1 HDMIPI Pro*1
58. jrhammond95003: SC-Pure 45/49*1, UCbalancer KIT*5
59. rpiaudio SC-Pure 22/24 *1 SC-Pure 45/49*1 FiFoPiQ7*1 StationPiPro*1 MonitorPiPro*1 StationPi PCB (free stuff) *1 ShieldPi PCB (free stuff)*1
60. seb2 SC-Pure 45/49*1, FifoPiQ7*1, UCbalancer KIT*1, UcPureMkIII*1, MonitorPi*1, StationPi PCB (free stuff)*1
61. Murdoc SC-Pure 22/24*1, FifoPiQ7*1, HdmiPi Pro*1, TransportPi AES*1, StationPi Pro*1, LinearPi MkII Dual*1, LinearPi MkII Solo*1, UcConditioner MKII 5V*1, UcPureMkIII*2, UCbalancer KIT*4, MonitorPiPro*1, GPIO extender*3, StationPi PCB (free stuff)*1,
62. crm75 SC-Pure 45/49*1, UCBalancer KIT*1,MonitorPiPro*1,StationPi PCB (free stuff)*1
63. isander Sc-pure 22/24*1
64. heathkit SC-Pure 45/49*1
65. dlucksinger SC-Pure 45/49*1, FifoPiQ7*1, UcPureMkIII*1, HdmiPiPro*1, MonitorPiPro*1, UcConditioner5v*1, ReceiverPi*1, GPIOextender*1
66. flocchini SC-Pure 45/49*1
67. jctong89 SC-Pure 45/49*1, FifoPiQ7*1, TransportPi AES*1, MonitorPiPro*1, UCConditioner MkII 3.3V*1, ReceiverPi *1, StationPi PCB (free stuff)*1
68. mkrasauskas SC-PURE 45/49*1, FifoPiQ7*1, HdmiPi Pro*1, TransportPi AES*1, LinearPi Dual MkII*1, ShieldPi PCB (free stuff)*1, PurePi *1, MonitorPi *1, StationPi PCB (free stuff) *1, UcConditioner MKII 3.3V *1
69. Janosch Simon SC-Pure 45/49*1 StationPi PCB (free stuff)*1
70.Karoly60 SC-Pure 45/49*1,MonitorPiPro*1, UCbalancer kit*4,StationPi PCB /free /*1
71. MecII SC-Pure 45/49*1
72. Krachluigi SC-Pure 45/49*1, FifoPiQ7*1, PurePi*1
73. MartinJohn SC-Pure 45/49*1, TransportPiAES*1, FifoPiQ7*1, GPIO spacer*1,UcConditionerMkII3.3v*1, LifePO4 Mini 3.3V*1, MonitorPi*1, Universal GPIO Extension Kit*1, StationPiBCP(freestuff)*1
74. Miklau SC-Pure 45/49*1, FifoPiQ7*1, MonitorPi Pro*1, GPIO Extension kit*1, UcHybrid 3.3v*1
75. ichiban SC-Pure 45/49*1, SC-Pure 22/24 *1
76. victhor34 SC-Pure 22/49*1, FifoPiQ7*1, LinearPi MKII Dual*1, StationPi PCB (free stuff)*1
77. J-Ras SC-Pure 45/49*1, FifoPiQ7*1
78.Tamra SC-Pure 45/49*1
79. QZS SC-Pure 45/49*1,FifoPi Q7 *1, PurePi *1,MonitorPiPro*1,UcConditioner3.3V*1,UcConditioner5V*1,UCbalancer KIT*3,HdmiPiPro*1,shieldPi Pro/MKII*1,UCPureMKIII*1,StationPiPro*1,StationPi PCB (free stuff)*1,SquarePi KIT*1,Adapter KIT*1.
80. Batenet SC-Pure 22/24*1,UCbalancer KIT*2
81. yveskoala SC-Pure 45/49*1
82. flohmann SC-Pure 45/49*1, TransportPi AES*1, FifoPi Q7*1, PurePi*1, UcConditioner 3.3V*1, MonitorPi*1
83. Spacejack SC-Pure 45/49*1
84. Smartdriver SC-Pure 22/24 *1, MonitorPiPro *1.
85. qwertyl SC-Pure 45/49*1, FifoPiQ7*1, LinearPi MkII Dual*1, UcConditionerMkII 5V*2, UcPure MkIII*2, UCBalancer KIT*2, MonitorPi*1, GPIO Extension Kit*1, StationPi SMT*1, LinearPi Standoff/Screw Sets*2
86. Akasaka SC-Pure 45/49*1, FifoPiQ7*1, MonitorPi Pro*1, UCBalancer KIT*5, UcPureMkIII*5, ShieldPi Pro/MKII*1, LinearPi MkII*1
87. kit0093 SC-Pure 45/49*1, FifoPiQ7*1, HdmiPi Pro*1, UcPureMkIII*1, TransportPi AES*1, StationPi PCB (free stuff)*1
88. geoturbo SC-Pure 24, StationPi PCB (free stuff)*1
89. chih SC-Pure 45/49*1, OPA861 I/V *1, PurePi*1, StationPi PCB (free stuff)*1
90. calebwong SC-Pure 49*1, StationPi PCB (free stuff)*1
91. ChrisMH SC-Pure 45/49*2, FifoPiQ7*1, TransportPi AES*1, UcConditioner 3.3*1, PurePi*1, UcPureMkIII*2, UcBalancer*2, MonitorPiPro*1
92. elfischiso SC-Pure 22/24 *1, SC-Pure 45/49*1, FifoPiQ7*1, TransportPi AES*1, StationPi PCB (free stuff)*1
93. acg SC-Pure 45/49 *1, ReceiverPiRpo *1, TransportPiAES * 1, HDMIPro x 1, FiFoPi Q7 *1, MonitorPiPro * 1, uCPureMKIII x 7, ucBalancer *7, StationPiPro/control cable * 1
94. Subbu K SC-Pure 45/49 *1, MonitorPiPro * 1, UcConditioner MKII 5V * 1, Linear Pi MKII * 1, StationPi Pro SMT * 1
95. harry925 SC-Pure 45/49*1
96. gringo117 SC-Pure 45/49*1
97. Luca72c SC-Pure 45/49*1, LinearPImkIIDual*1, McFIFO*1, McDualXO*1
98. mksung SC-Pure 45/49*1
99. mnichols30030 - FiFoPiQ7*1, 13 mm standoffs*1, 11mm standoffs*1, TransportPiAES*1
100. Michel8 SC-Pure 45/49*1, HdmiPi Pro (17B)*1, FifoPi Q7 (1D)*1, PurePi (48A)*1, MonitorPi (49A)*1, 18650 3.2v*2, 2.5mmx11mm metal standoffs lot of 4 sets (12B)*2, Acrylic cap (51A)*1
101. Davidseow SC-Pure 45/49*1 , UcConditioner 3.3V*1 , HDMIPI pro*1 , reclockPi*1 , receiver Pi pro*1 , PurePi*1
102. michaelagiles FiFoPi MA*1
103.CxTurbo SC-Pure 45/49 *1, TransportpiAES *1, ucPureMKIII *3, ucBalancer0*3, GPIOextender1*1, MonitorpiPro*1
104. lorde73 StationPi Pro *1, FifoPi Q7 *1, TransportpiAES *1, UcPure MKIII *1, ShieldPi PCB *1 (free)
No problem. For future purposes, I recommend experimenting copying and pasting the "Current" whole interesting list.
For new users, I recommend just copy and paste the "Current" interesting list then just paste and post. Don't make any edits until you are comfortable copying and pasting the whole "Current" interesting list.
No one is going to mind if it's just a copy and paste of the "Current" whole interesting list with zero edits.
It's good to learn for future edits for GB2023 or GB2025.
When ready and comfortable, just copy and paste the "Current" whole interesting list again, edit your list then post.
Good solid choices. I'll re-evaluate the LinearPi5V as their are multiple options to power (2) 5V.
104. lorde73 SC-Pure 45/49*1, StationPi Pro *1, FifoPi Q7 *1, TransportPiAES *1, UcPure MKIII *1, ShieldPi PCB *1 (free), UCBalancer *1, LinearPi MKII 5V*1, UcConditioner MKII 5V*1
60. seb2 SC-Pure 22/24*1, StationPi PCB (free stuff)*1
92. elfischiso SC-Pure 22/24 *1, StationPi Pro *1, FifoPiQ7*1, TransportPi AES*1, StationPi PCB (free stuff)*1
103. CxTurbo SC-Pure 45/49 *1, TransportpiAES *1, ucPureMKIII *3, ucBalancer0*3, GPIOextender1*1, MonitorpiPro*1
105. duck552 SC-Pure 45/49 *1, FifoPiMa *1, UcPure MKIII *4, UCbalancer KIT *4, GPIO extender *4
106. michl2604 SC-Pure 45/49*1, FifoPiQ7*1, StationPiPro*1, DDDAC U.FL input adapter *1, UCbalancer KIT*1, UcPureMkIII*1, LinearPiMKII Solo*1
Added my 'interested for group buy items' at the end of this list (#106)
106 iano SC-Pure 45/49 *1, StationPi Pro SMT * 1, FifoPi Q7 *1, PurePi*1, MonitorPiPro * 1, UcConditioner MkII 3.3V*1, TransportpiAES *1, UcConditioner MKII 5V * 1, Acrylic cap (51A)*1, IsolatorPi * 1, DSD/DOP Decoder Board * 1
Added my 'interested for group buy items' at the end of this list (#107)
107. Gsabest: SC-Pure 45/49*1
60. seb2 SC-Pure 22/24 *1, StationPi PCB (free stuff)*1
Actually, it was not the end of the list ;-)Added my 'interested for group buy items' at the end of this list (#106)
Added my stuff again...
108. michl2604 SC-Pure 45/49*1, FifoPiQ7*1, StationPiPro*1, DDDAC U.FL input adapter *1, UCbalancer KIT*1, UcPureMkIII*1, LinearPiMKII Solo*1
109. roderickvd SC-PURE 22/24 *2
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
