LifePO4 Mini 3.3V user's manual
LifePO4 Mini 3.3V user's manual V0.9b
LifePO4 Mini 3.3V is a low cost LifePO4 power supply without any compromise on performance.
However, the performance of the two battery cells parallel configuration could be even better than before.
Please let me know if there is any mistake or anything needs to be revised.
Thanks,
Ian
Thanks,
Ian
1. Iancanada 1*SiniPi fully assembled, 1* UcPure, 1* LifePO4 Mini 3.3V, 1*Oven KIT, 2*6” and 2*10” SMA cable
2. Cerole 1*SiniPi fully assembled, 1* UcPure and 1*Oven KIT
3. A123 1*SinePi fully assembled with RF relay (SiniPi fully assembled)
4. hires 1 * UcPure
5. pz1 1* siniPi fully assembled, 1* LifePO4 mini 3,3V
6. schiirn 1*SinePi fully assembled with RF relay
7. linh0983 1* RelockPi, 1* LifePO4 Mini 3.3V
8. terry22 1*SinePi fully assembled, 1*Ucpure 15v, 1*Oven KIT
9. Narukas 1*SinePi fully assembled, 5* UcPure, 1*Oven KIT, 2*6” and 2*10” SMA cable
10. Raj1 2*UcPure
11 Eduard 1* SinePi fully assembled
12 SimonJ 1* SinePi fully assembled (can be kit if needed), 1* UcPure, 1 * Oven KIT, 1* LifePO4 Mini 3.3V, FiFoPi Q3
13 Oyvind 1* LifePO4 mini 3,3V
14. kunlun121 1*SinePi fully assembled, 2*UcPure, 1*Oven KIT
15. Tubo- 2 SinePi fully assembled, 2*UcPure, 2* Oven kit, 2*6” and 2*10” SMA cable
16. wlowes 1*SinePi NOT assembled
17. AirAir 1*UcPure
18. trial and error 1*SinePi fully assembled, 1* Oven Kit
19. jrocker 1*SinePi fully assembled, 2* UcPure, 1*Oven KIT, 2*6” and 2*10” SMA cable
20. ernesternest 1* UcPure, 1* LifePO4 Mini 3.3V, 1*Oven KIT
21. puuchan 1*SiniPi fully assembled
22. M_Balou 1* SinePi fully assembled, 1* Oven KIT
23. Atom6422 2* SinePi fully assembled, 2* Oven KIT, 2* LifePO4 Mini 3.3V, 2* ReClockPi, 1*StationPi
24. Photochum1 1 x SinePi fully Assembled, 2 x ReClockPi, 1 x StationPi Pro, 1 x UcPure, 1 x Oven Kit, 1 x HDMI Transmitter MK II
25. jimk04 1x sinepi assembled 1 x oven kit.
26. Paul M 1x SinePi fully assembled with RF relay, 2x Oven kit
27. efrank 1x SinePi Fully Assembled w/Relay, 1* LifePO4 Mini 3.3V
28. Ilgavro 2x sinepi not full assembled
29. trung224 1x SinePi full assembled, 2x Oven kit, 1x UcPure
30. mksung 1*SinePi SMT finished KIT, 1* UcPure
31. Morde 3* LifePO4 Mini 3.3V
32. casshan 1*SiniPi fully assembled with RF relay, 1* LifePO4 Mini 3.3V
33. Supersurfer: 1x UcPure, 2x LifePO4 Mini 3.3V
34. igor61> 2x LifePo4 Mini 3.3V, 1x UcPure
35. Subbu K: 2*LifePo4 Mini 3.3V, 1*LifePo4 Mini 6.6V
36. Greg Stewart 2x SinePi fully assembled with RF relay, 2x Oven KIT for SC-cut crystal, 2x 6" SMA coaxial cables
37. blue9527 1*UcPure
38. Mobilux 1*SinePi fully assembled with RF relay, 1*UcPure 3.3v
39. jiacheng 1* SinePi SMT finished KIT, 6* UcPure, 1*Oven KIT, 2*6” and 2*10” SMA cable
40. byun3652 UcPure * 4
41. AudioDAC 1*SinePii fully assembled with RF relay, 1* UcPure, 1*Oven KIT, 2*6” and 2*10” SMA cable
42. Rrbs 1x SinePi fully assembled with RF relay, 2x 6" SMA coaxial cables
43. Sebbyp 3x SinePI fully assembled with RF relay (can take the finished kit too), 10* UC Pure 4x Oven Kit for SC-Cut Crystal 2x 6" SMA Cable
44. Stephen1212b 2*SinPI fully assembled with ref relay, 2* Lifepo4 mini, 2* oven kit, 4 * 6” sma cable
45. triode4 2 x SinePi fully Assembled, 2 x ReClockPi, 1 x StationPi Pro, 1 x UcPure, 1 x Oven Kit, 2 x HDMI Transmitter MK II,1 x FIFOPI Q2, 2*6” and 2*10” SMA cable
46. S610adam 2x UcPure
47. Aguaazul: 2 * 1* SinePi fully assembled (can be kit if needed), 3 * UcPure, 2 *10" SMA coaxial cables, 4 * 6" SMA coaxial cables. 1 * StationPi Pro,
48. sumire 1*SiniPi fully assembled, 2*Oven KIT, 4*6” and 2*10” SMA cable, 1*ReClockPi,1*StationPi Pro,
49. geoturbo 1* reclockpi, 1* sinepi kit, 2* 6" sma cable, 2* ucpure, 1* stationpi pro
50. bferg 1*reclockpi 1*sinepi fully assembled (kit ok if needed) 1*fifopi 1* transport pi 1* Stationpi pro
51. duster1 1*SinePi SMT finished KIT
52. JanVeg 1x SinePi fully assembled with RF relay and 2*6” and 2*10” SMA cable and 1 UcPure
53. rowli 3 x UcPure
54. ibraino 1*SiniPi fully assembled, 1* UcPure, 1* RelockPi, 1* LifePO4 Mini 3.3V
55. Michl2604, 1*ReclockPi, 1*LifePO4 Mini 3.3V, 1*LinearPi Solo
56. seatrope, 2* Oven Kit.
57. Rullex 1*SinePii fully assembled with RF relay, 2* UcPure, 2*6” and 2*10” SMA cable, 1*ReciverPi
58. drone 1*SinePii fully assembled, 2*LifePO4 Mini 3.3V, 3* UcPure, 2*6” SMA cable, 1*LinearPI, 4*2" uFl cable
59. Myint 67 life po4 mini 3.3v
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
60. acg 3xUcPure
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
60. acg 3xUcPure
Thanks Ian!
Are the battery holders included?
Thanks,
Ian
Battery holders can not be included as default. They are too big so with them the LifePO4 Mini will no longer be shipped in a bubbled envelopes. Shipping can be increased. But I'm trying to provide extra battery holders together with assembling service in case somebody has difficulties doing this job.
Ian
Ian
A lot of options from Amazon
https://www.amazon.ca/uxcell®-Plast...ds=26650+battery+holder&qid=1634568247&sr=8-5
Ian
Ian
LifePO4 Mini 6.6V user's manual
LifePO4 Mini 6.6V is a low cost LifePO4 power supply, but without any compromise on performance.
Please find the attached LifePO4 Mini 6.6V user's manual V0.9b
Thanks,
Ian
Thanks,
Ian
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
60 JimS 1*SiniPi fully assembled, 1* UcPure, 1* RelockPi, 2* LifePO4 Mini 6.6V
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
40. byun3652 4* UcPure, 2*LifePO4 Mini 3.3V
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
55. Michl2604, 1*ReclockPi, 1*LifePO4 Mini 3.3V, 1*LinearPi Solo, 4*6" uFl cable
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
Edit to jimk04 requirements
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
25. jimk04 1x sinepi assembled 1 x oven kit. 2 x LifePO4 Mini 6.6V, 2 x LifePO4 Mini 3.3v , 1 x StationPi/ pro if available
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
Edit to schiirrn requirements
4. hires 1 * UcPure
6. schiirn 1*SinePi KIT
10. Raj1 2*UcPure
17. AirAir 1*UcPure
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
Edit to AudioDAC requirements
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
41. AudioDAC 1*ReclockPi, 1*SinePii fully assembled with RF relay, 1* UcPure, 1*Oven KIT,2*10” SMA cable
__________________
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
__________________
Kunlun121 (no. 14) updated
4. hires 1 * UcPure
10. Raj1 2*UcPure
14. kunlun121 1*SinePi fully assembled, 4*UcPure, 2*Oven KIT
17. AirAir 1*UcPure
__________________
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
__________________
Hi Ian,
I'm currently considering the LiFePO4 Mini 6.6V. In the Manual it states 9V-12V DC Input, but on the PCB it states 9V-18V DC Input.
I'm okay as I just checked I'm using 12V on the MKIII, so I will use the same 12V DC power supply on the LiFePO4 Mini 6.6V. But it would be nice to know if you can go higher in the future if needed.
I'm not ready for the UcPure since I'm a good year behind in projects, but the 6.6V fits my needs at this time since I use it to power the LPS 5V. Currently using my own 6.6V A123 Battery solution, but no charging capabilities. This is a much cleaner and user-friendly way. Another great Ian solution.
Thanks for your 6.6V battery to power LPS 5V suggestion earlier in the year. An UcConditioner 5V on top is icing. I avoid Mains at all cost for anything audio-related, so this is an extremely handy tool to get 5V. I try to avoid 5V too, but sometimes it cannot be avoided due to the USB.
3. A123 1*SinePi fully assembled with RF relay (SiniPi fully assembled), 1*LiFePO4 Mini 6.6V
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
60. JimS 1*SiniPi fully assembled, 1* UcPure, 1* RelockPi, 2* LifePO4 Mini 6.6V
4. hires 1 * UcPure
10. Raj1 2*UcPure
17. AirAir 1*UcPure
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
