Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Some photos of Ian's board installed in a Denon DN-C110 rack mounting CD player. It matches my Self/Huff preamp and Dac 1U cases.
Its nothing special as a Cd player (uses a PCM 1791 dac) but makes a superb transport. It's all steel construction, detachable rack frame, sturdy Sanyo mechanism and controls that have a great feel made it a bargain at £35 delivered (from Ebay)
I could probably have squeezed the dac inside it as well, but I am building three balanced dacs. A dual TDA1541, a dual AD1865 and a quad AD1862 (mono dac) to do some comparisons.
The pcm signals are transmitted over a 50cm cat5e stp cable to the dacs.
Ian, what is the fan-out of the pcm outputs? I was thinking of connecting all three dacs pcm inputs together. The outputs have been checked with my scope are clean though that was with no load.
@batteryman
Your project looks very nice. You are the first one doing it this way. Very smart!
The PCM board was designed capable for driving mono block DACs. So, there will be no problem. But need to make sure cables are in same length.
LVDS can be a better option tor transfer signals in distance more than 20cm. I'll have a pair of HDMI boards (transmitter and receiver) for this kind of application soon.
You can also place a FIFO before the PCM board to improve sound quality.
Thanks for sharing.
Regards,
Ian
@batteryman
Thanks for sharing.
Regards,
Ian
Hi Ian,
Thanks.
Will your HDMI tx/rx have panel mounting connectors fitted, and PH2 for the TX input and RX output?
I will read up about your fifo as it will probably be a future upgrade when I have decided which dac(s) I prefer. (I will be using Sowter 9545 balanced dac I/V transformers, probably with a 4pole 3way switch for easy selection of the dac)
IanS
problem with i2s to pcm
Hi
It has stopped working, fifo reclocker and dualxo work correctly, but the led i2s does not turn on. When done some tests the led was turned on when the i2stopcm was turned on (the dac) but immediately the led i2s was turned off, now it does not turn on anymore. I think he died. Any idea what I can do?
Ian, is it possible to buy an i2stopcm?
Can someone sell me one?
regards
New Ian GB2018 interesting list
I developed some new audio gears this year. I'm really happy with them. So I decide to run a new GB2018 to make those solutions can be shared by the community members. Here is the list of the new items:
1. FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator
2. LifiPO4 pure power supply
3. ESS controller
4. Dual Mono ES9038Q2M DAC HAT
5. ES9028Q2M DAC HAT
6. I/V STD standard I/V stage
6. Transformer I/V PCB mini KIT
New documents will be updated to my gitHub very soon:
GitHub - iancanada/DocumentDownload: Download documents of Ian's products
More new pictures will be updated to my Flickr:
https://www.flickr.com/photos/135181977@N06/
Links to my R&D thread:
https://www.diyaudio.com/forums/dig...mate-weapon-fight-jitter-468.html#post5527560
https://www.diyaudio.com/forums/pow...epo4-battery-power-supply-18.html#post5579407
https://www.diyaudio.com/forums/pc-...i2s-dac-hats-raspberry-pi-69.html#post5609038
Note1* All old items will be still available, which are here:
https://www.diyaudio.com/forums/gro...us-i2s-pdif-fifo-kit-buy-243.html#post5111232
Note2* Prototype pictures may different from finial products
Production normally takes two weeks. So they are coming soon. I don't have the pricing before production finished. But I'll try to keep them as low as possible as I did before.
Here is the new interesting list for Ian GB2018, please add your DiyAudio ID and what you are interested in to the list. You don't have to buy if you change your mind then.
Interesting list starts here:
1. iancanada 1*FifoPi, 1*LifiPO4 power, 1*EssController …
2.
Ian
WOOHOO! Thanks Ian.
2. Crom 1 x FifoPi, 3xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB minit kit (and if you have any left: The RPi I2S adapter that enables the ESS controller to be used as an external controller)
Joined 2009
3. Oyvind 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB minit kit
4. Pistollero 1 x FifoPi, 2xLifePO4 power
5. MikeyFresh interested in 1 pc. each of all 7 items listed in this GB
6. Randytsuch 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
7. necplusultra 2 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB minit kit
8. szczemirek 1 x FifoPi
9. casshan 1 x FifoPi, 1 x LifiPO4 power, 1 x Ess Controller
4. trung224 1xLiFePO4 power
10. zapio : 2 x FifoPi , 4 x LifiPO4 power, 1 x Ess Controller, 1 x transformer I/V PCB minit kit, 1 x I/V STD standard I/V stage, 1 x Dual Mono ES9038Q2M DAC HAT
11. trung224 : 1xLiFePO4 power
12. Sq225917 : 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB minit kit, 1 x Dual Mono ES9038Q2M DAC HAT
13. passive420: 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB minit kit
