Hello all,
I would like to connect my Ayon DAC via i2s to the ESI Juli@ card. The connections on the Ayon are through RJ45 as under:
Pin 1: GND
Pin 2: BCK
Pin 3: GND
Pin 4: LRCK
Pin 5: GND
Pin 6: DATA
Pin 7: GND
Pin 8: GND
I would be grateful if someone could tell me the corresponding Pins on the Juli@ card. I will use CAT5 or CAT6 cable.
Thanks in advance,
Max
Pin 1: GND
Pin 2: BCK
Pin 3: GND
Pin 4: LRCK
Pin 5: GND
Pin 6: DATA
Pin 7: GND
Pin 8: GND
Thanks in advance,
Max
I'm confused about where all the GND (ground) connections go. Do these all go to the same place? "J7 Pin 5 -> Digital VSS" or are they seperate grounds?
errmm they go to ground you will see this set up in quite a few i2s implementations. you will also see it in ethernet and many other communications protocols. basically its that way so each signal can be twisted with ground for better noise reduction. so if you are making your own interconnect, just use a tightly twisted pair for each, and if you use a pre made cable like eSATA or something, you should find that there is a number of twisted pairs already, just use them as they are and connect to ground as you can
Since the Ayon has an RJ45 I2S connector, I cut a ethernet cable and soldered the corresponding wires as per the Ayon pinout to the Juli@. I get sync on the Ayon but when I play a test sound through windows, all I can here is static.
Any ideas? Thanks.
Cable length is less than a foot.
Any ideas? Thanks.
Any ideas? Thanks.
There are several I2S variants. Juli's ICE1724 is configured to use 24bit word, for details see http://alsa.cybermirror.org/manuals/icensemble/Envy24HT091DS.pdf , register CCS06=0xF8, see also register MT02 and figure 4-2.
So does this mean, the 2 are not compatible?
- Digital Line Level
- I2S from Juli@ PCI sound card
