I got a little further this weekend and my amp and psu are near complete. I now use the STPS745F Schottky diodes for recification.
I also modified the filament and heater supply for the 300B and 5687 tubes. This is the result http://www.homepages.hetnet.nl/~rjonkers/psu.gif
When I connect my preamp and cdplayer, I still hear a little hum when I listen near my speakers. Is this probably because the whole thing is still on my workbench, of does a part of my PSU introduce this hum? What is the best way of investigating where the hum comes from?
Hum investigation
Hi Ralph,
If the hum is independent of volume setting, and of source connection, then it may be power supply or earthing.
If the hum happens only when the volume control is turned clockwise, it may be coming from the source. Try short-circuiting the input and check again.
If the hum appears the moment a source is connected, it could be earth currents. Make sure all equipment is powered from the same socket or socket group.
Ther's a few to keep you busy!
BTW Glad to hear you got your Schottky's connected finally.
Hi Ralph,
ust wanted to let you know I finished the PSU. Next is the amp ...
http://www.jonkers.net/audio/psu1.jpg
http://www.jonkers.net/audio/psu2.jpg
http://www.jonkers.net/audio/psu3.jpg
Ralph
Ralph
All finished and up and running. Will post some more pics and description soon.
http://www.jonkers.net/audio/gereed.jpg
