I need help with this amplifier...
1. Set the vas stage current to to 20mA and if you use only one pair of otput mosfets, remove R21 and R22, they`re useless.
2. There is a mistake in your circuit! :
Q7 and Q8 should be PNP
Q5 and Q6 should be NPN !!!
OTHERWISE IT WILL NOT WORK...
3. You can raise the VAS current by increasing R5 and R6 value or decreasing R12,R14 and R15 value.
I think you`ve made enough of Bora amplifiers...
PoZdrav!
