But what is wrong with an att. network before the driver?
Apart from screwing up the damping factor? Nothing.
An even easier (and much more safe one) would be to just use an L-pad attenuator before the NCore. Not as ideal but in the real world it shouldn't matter.
Well, in the case of pos, who I think said he could hear hiss out of the nc400, it might matter to some degree.
An easy way to remove R141:
First splatter the top and both sides of the resistor with some solder.
Then heat both sides at the same time by laying the soldering iron and when heated just push the resistor away, or push it off with a tweezer.
As I have said before - splatter the ENTIRE resistor with solder, and it will just follow the solder iron when you remove it. Very very simple, and with low risk.
Agree.
Now for a more interesting one - advice for replacing (instead of removing) R141, for someone who wants a resistor, but with a different value?
Then you should use a nice 20 watt class A amp for a 113db driver
I came from a 8W class A ...
The ncore is definitely better
no, trust me dont push the resistorjust push the resistor away
what is the iron temperature to use ? 300°C ?
This is good advice
If I had a 113db driver then I would use 2W tube amp.
I'm sorry but I don't get it. that resistor is at the edge of the board which should make things easier. and one can practice on a scrapped board. and how in the world is taking a dremel close to the NCORE safer than using a soldering iron? I have worked with surface mount parts, not much but enough to tell you it can be done and I don't have the steadiest hand (due to alcohol and hard drugs abuse, joking) or the best vision (wearing glasses since I was 4) and I managed to do it fine.
On the other hand, some drivers do better with higher source impedance, as per Hawksford in his article on current drive.
Yes, if you drive them with a current drive circuit. If you have a conventional voltage-driven amp, higher source impedance is not beneficial.
If you put a series resistor between your amp and driver you do get most of the benefits of current drive (lower distortion), but of course you loose a lot of power along the way...
But you'd have to use quite a large resistor and even if you use a large one a true current source amp is better.
I'm still hoping hypex will produce a current source NCore, ideally a lower powered one or a dual channel NCore module but I wouldn't complain if it was a normal single channel one
With DSP being so widespread now the different driver response shoulnd't be an issue, would make an awesome combo with the DLCP for sure =)
Agree!!! DON'T remove the resistor!!!
Dynamics, openness and everything suffers big time on every other speaker tried, except for my 108 db horns, which in fact do even better with a pair SILK transformers in front of the ncore instead of no resistor
(and it was a quite delicate job to solder it back on ;0)
Are you saying removing R141 degrades the sound somehow?
depends:
at a evening i Copenhagen Hi-Fi club (Storkøbenhavns Hi-Fi Klub Hvidovre) last year, the ncore with linear PSU (and R141) totally trashed the ncore with SMPS (no R141)
the no R141 ncore sounded extremely thin, flat and boxy driven by 3 different preamps (active) connected to insensitive <86db speakers (with Duelund crossovers)
http://www.steenduelund.dk/download/duelund-filter.pdf
later I found out the only preamp I had that still could reveal the true level of the ncore (without R141) is my E88CC based (line stage) Tubeguru RR
(with the R141 back in place the SMPS fed ncore is ahead of the linear PSU ncore )
So again I have to say: whatever you put in front of the ncore IT will shine through in all its "glory", the ncore being the most revealing and "invisible" amp, you will hear your front gear more than anything else . Changing the ncore input, will make this even more true, and put more demand on the pre for sure, and one can TOTALLY forget all about a passive pre
just experience ;0)
Il-Bahnsen
According to Bruno, the performance of the NC400 is slightly improved by removing R141, as the amount of feedback increases by 4,17 times.
Now this is very interesting to me
if all else remains equal, the lower input sensitivity (which is really the lower overall rate of amplification due to increased feedback?) should just come down to the pre to deliver, but the "magic", power and effortlessness was lost in even the cases were the source had plenty left
Well, the problem was most likely somewhere else than the Ncore.
In my case, I had a slight improvement in sound quality by lowering the Ncore's gain, as the gain structure of my system improved.
Different equipment, different speakers, different places (4), different listeners, = same results more or less
Have you tried comparing to standard ncore with transformer in front for lowering gain?
works best for me anyway
Have you tried with different pre's or speakers in your system?
- Class D
- Hypex Ncore
