I picked up many cases of OEM tweeters and various drivers that I will be listing.
1st up, pretty standard 1" polycarbonate dome used in well..everything it seems! Labeled JL 4ohm 3 watt. While these are labeled 3w I would guess that's a real 3w and probably 30 watts with a proper crossover network
I have about 600 of these on hand. willing to make some mega deals!! Let's start at $1ea and work some bargains from there!
Anyone want to do a cool line array??
Next up are some nice metal dome tweeters. these have rubber surrounds and I think they said these were polydax?? I have two different types of brackets for these. but with some careful prying the bracket can be removed. These were used in upper end Automotive applications. Let's start these at $5each and work some deals from there.
I'm interested in some of the poly tweeters. Are those the Parts Express clearance model from some time ago? I think they were Onkyo??
These are from a major OEM autosound mfg, not sure who made them originally. these are not the same as from PE. how many hundred would you like??
Ok I think I have figured out what this stuff was designed for!!! The metal dome tweeters I am betting are NOT aluminum, they are titanium!! 19mm titanium.
In my other post i have some metal cone midrange drivers. the SAME one's pictured here:
JBL Premium Audio for your Venza the 80mm midrange drivers are the exact same mid drivers I have listed! walla!!
Ok so these are commonly called Mylar domes. not sure if it makes a difference or not. I need to move this out! Looking for any sort of offers reasonable or not! I just may take it!
Per our PMs: I know catching up after Easter slowed things down a bit... no problem, I understand. I appreciate you checking the condition of the original packing... glad you found the issue and are remedying that. Glad your feeling better too. Sorry the snow storm is so bad. I'm in no real hurry here so please don't take any chances on bad roads just to ship the tweeters. In fact, I'd suggest letting the carrier pickup from your house. Please PM the tracking number when you have it. GREAT DEAL ON THESE TWEETS!!
