HP amp circuit just for interest
Disabled Account
Joined 2010
I found this old circuit,
I remember building it years ago.
I have no idea where it came from..perhaps someone may know?
It was just drawn on a scrap of paper.
I thought it might be interesting for someone.
No coupling caps.
You can use it to drive cables as well (Buffer)
M. Gregg
45mA of bias current? Where to? Through the headphones?
Have I fallen asleep with my eyes open, again?
Add A DC blocking capacitor to protect the headphones.
Add a load so that the output transistor can flow some bias current.
Through the 330r resistor which goes to -15V.
There should be no significant offset.
It's a very common design, but has way too much gain for most applications.
No. +15V -> BD135 -> 330 Ohms -> -15V.
The weak points are:
- (Very) prone to (V)HF oscillation. Add at least a base stopper resistor (~100 Ohms).
- Asymmetric clipping produces DC offset at clipping.
- Make sure the BD135 has high current gain (BD135-16)
- No DC protection for the headphones in case of component failure or DC at the input.
Disabled Account
Joined 2010
:D
I can't remember which Op amp I used Lm833 possibly I remember trying a few different ones..and a small Heat Sink on the BD135...
I'm sure I had another version of this as well...
M. Gregg
