WARNING: Tube/Valve amplifiers use potentially LETHAL HIGH VOLTAGES.
I may be wrong, but 12V seems just a little low for correct operation. What is this circuit to be used for?
edit: Are you using this for a distortion pedal? If so, it should work fine. Just don't use electrolytics for coupling.
