Hello. how to switch my X1 preamp voltage 220V to 240V. Thank you for your answers
E edyson Member Joined 2010 2010-11-15 5:18 pm #1 2010-11-15 5:18 pm #1 Hello. how to switch my X1 preamp voltage 220V to 240V. Thank you for your answers ••• More options Share A AndrewT R.I.P. Joined 2004 2010-11-15 6:47 pm #2 2010-11-15 6:47 pm #2 Hi, does the transformer have dual 0-110/120Vac tapped windings? If not, then 220Vac is considered the same as 240Vac, since both are within the tolerance range of the mains electricity suppliers. ••• More options Share Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button.
