I've been told that leaving pins that aren't being used and leaving simply disconnected is a bad idea. That will increase power consumption, noise, etc. I know how to do it in a op amp, but I'm having some difficulty with this DAC chip. I won't use the S/PDIF function.
PCM2903C Stereo USB1.1 CODEC with line-out and S/PDIF I/O, Self-powered (HID Interface) | TI.com
I'm guessing that the S/PDIF input should be tied to ground, should I take any other precaution? And what about the output? If I do the same to it, won't that possibly blow the chip due to overcurrent, or create noise of some kind? Should it be connected with a resistor? A capacitor in parallel? How should it be done?
You reached this conclusion having read the datasheet ?
In my defense, it was the datasheet from a slightly different chip ¯\_(ツ)_/¯
The correct datasheet states the SPDIF input already has a pull-down resistor.
Ah. I missed that. I feel even dumber now
Thank you for helping a dummy!
- Digital Line Level
- How to properly terminate unused S/PDIF pins in a DAC (PCM2903C)?
