I usually wind to my first, and lowest, value then bring out a loop of wire a couple of inches long and return to the winding in the same direction till the next tap. I sample the inductance as I go with a very sharp probe, usually this doesn't require repairing the insulation. It does help to use some sealer, shellac or equivalent, to help bind the windings as they tend to want to spring open.
-David
-David
