I would like to build the S-5 K-12g tube amp kit (formerly the K-12m). This will be my first kit, so I'm kind of clueless. The kit is at:
http://www.s5electronics.com/tube.html
more info here:
http://www.siteswithstyle.com/VoltSecond/K-12M_AMP/K-12M_Push_Pull.html
Anyway, I'm interested in modifying the kit to be run as a dual mono design. Is this possible? What would it take? Would I be better off buying two of the mono kits (and connecting them both to the same pot) or buying one of the stereo kits (and buy another power supply)?
Thanks!
more info here:
Thanks!
downward_dog said:Thanks for the help. So if I buy two mono kits, send one channel of input to each, and wire the same potentiometer to handle both of the kits, is that all I need to do?
Yes, except you'll most likely have to buy a new pot since I would imagine the pots in the monoblocks are single units and you need a dual unit to control each monoblock. (You can of course just use the two separate pots controlling each channel separately.)
A good solution for you might be to build a "passive preamp". Just get a dual 100K potentiometer and mount it in a box. Add a 2 pole, 4 position rotary switch and four pairs of RCA jacks. That gives you a choice of four sources. Next take the "output" of the dual potentiometer to another pair of RCA jacks for your output to the monoblocks.
