How to connect headphones to old system?
Thanks Mooly. I can see the advantage of having the switch out of the signal path. Is there any disadvantage to simply unplugging the headphones when I don't want to use them instead of having another switch to ground them? Please excuse my ignorance, but are the resistors there only for when the signal is shorted, or do they serve a purpose while listening also? In other words, if unplugging the headphones is acceptable, do I still need the resistor while listening?
Administrator
Joined 2007
There is no problem plugging/unplugging apart from wear and tear on sockets etc.
The resistors work like this...
when listening the signal passes through the resistor. It is in series with the audio signal.
The only downside is that it raises the output impedance of the preamp (as seen by the power amp) by adding the value of the resistor chosen to the quoted output impedance of the preamp.
Does that matter ?... I would say the effect should be absolutely minimal for any normal well designed power amp if the resistor is reasonably low in value. It's easy to prove that to yourself. Just take an old interconnect that you can use between pre and power amp and cut it in half. Remake the ground continuity and then just add two resistors (one for each channel) in series with the signal conductor. 1K, 4K7, 10K try them all and see if you can detect any difference.
That's half of what they do...
The other thing is this. When the switch is in the "shorted position" they isolate the preamp output from seeing a dead short... which would remove the signal for everything :) So with the switch shorted the resistor appears as "load" across the preamp output.
So we have a compromise. The lower the better for the signal to pass through. And the higher the better when it comes to loading the preamp. So what we choose depends on the driving ability of the preamp. Most preamp stages, even if just opamp will drive 600 ohms fully.
Administrator
Joined 2007
