tranformer desing
http://schmidt-walter.fbe.fh-darmst...s_e/smps_e.html
www.alab-pro.com
www.alab-pro.com
transformer desing
http://schmidt-walter.fbe.fh-darmstadt.de/smps_e/smps_e.html
www.alab-pro.com
www.alab-pro.com
The effective area is 211mm^2 and the minimum area is 209mm^2. The B is 200mT at 25KHz.
I read the article but i am not very sure about the Vin_min and the Vin_max. if my supplied voltage is 20Vac peak to peak, what is the Vin_min? Vin_max is 20?
I read some articles saying that insulation is needed after every layer of coil and epoxy is added. Then cannot coil it from one end to the other and coil it back again.... do i need to cut the wire after a layer of coil then isulate it and continue again?
Thanks so much for replying..
- Class D
- How to coil a transformer
