data can be found in this link:
http://www.datasheetarchive.com/search.php?q=PCM64
technical advice needed:
1.How to adjust and calibrate Bit1 to Bit4?
2.electronics equipments needed for this calibration?
This datasheet seems to be new.
You can adjust with CD 1 kHz -60dB.
Bit 1 is most important.
You can listen with headphones and adjust so that the sine sounds as clean and pure as possible.
In the datasheet it looks like always the corresponding bit switch must be closed for calibration.
When all bits are adjusted, close all bit switches.
I don't know if those switches are necessary, maybe it is easier to adjust.
Equipment would be a spectrum analyzer, stand alone or PC+soundcard+software.
