Are these going to be portable or fixed installations? What are the SS15?
JBELL SS15 subs
If they are in one end of a 100' long room, getting 100db at the other end will require more than 100db at the sub.....but I don't know how much more.
200 bucks is not a lot to spend but if you have the amps and Rackdrive already and can build the cabs yourself, you can make it work for 200.
yeah i have the amp Crown XLS 2000 drivecore and driverack ,
i will use one channel for subs and the other for tops
I would look at a folded Tapped sub. The Pi12 is way out of your price range if you need to buy their flat pack.
yeah i posted here because i want to know what you guys think of the Pi12
i have a f150 truckHow big a box can you transport?
yeah those are xpensiveA pair of drivers come in at $270 - design uses 2 per enclosure
So $1,170 per channel X 4 channels = $4,6800 ex shipping
i will go the DIY route with one sub 1st
A few words of warning.......
I'm a beta tester of Planet10's EmKen (Eminence Beta12Lta in 'Ken enclosure), I had the wonderful thought of buying a second pair of drivers for the beta build enclosure and building a pair of 'subs' and doing local party hire...... My thoughts were a pair of 'Half' Jensen Imperials.
Then I looked at the cost of drivers - £400 ($600) each
Soooo...... I'm looking into a sealed enclosure with a Eminence 15" (maybe an 18"). Even with 'reasonably priced' components, the cost of 6 or 7 8ft x 4" sheets of 25mm BB ply makes one draw breath sharply.
yeah, so i think the SS15 is a no brainer
have you see the thread ?
is made with just one sheet of plywood with a 3012 15" driver
you can use several from the list, is flat from 40 to 100 i think
here is the JBELL SS15 sub thread
http://www.diyaudio.com/forums/subwoofers/170771-single-sheet-th-challenge.html
is you buy 6 or 7 sheets as you stated , you can make 6 or 7 subs ( altough you want an even number ) so make 8 and rock the house
check the specs on the thread above
it rocks and dont break the bank and you can build with 1/2 batlic birch plywood so your back is happy also
ppslic, ppsl is bandpass ported design ?
its bassreflex ,using 2 speakers per cab.eliminating even order harmonics.
happsl
i have seen that thread
what i found difficult is navigate to 40 pages of posts to gather the info
would be nice that the thread starter can post on the 1st page the links
to the diagrams and parts and stuff
like Jbell did on his SS15 thread
lol
it is a monster
but i dont want that big and heavy and besides that will take more than my 150-200 budget to DIY a sub
i think i will make a slim SS15 with the dayton pa310
http://www.diyaudio.com/forums/subwoofers/170771-single-sheet-th-challenge-185.html
it is a monster
lol, I should really ask what application a sub is for b4 I spout off!!!
Usually, a 40hz ported (with protection below that) for pa will get you awesome results, assuming you can get flatly down to 40hz anyway).
Jbl 4508 and 4509 dual 15" cab just happens to be tuned to 40hz.
I think bandpass can work well for pa.
Norman
Norman
- Subwoofers
- how this design looks ( PI )
