how is it measuring?
I don't have very good experience with stand alone Dynamic Signal Analyzer, the oldish HP analyzer in my work place seems to have too high noise floor.
But I have good results working with HP8903B analyzer. Though no FFT feature, its low noise preamp allow me to see -90dBFS signal. Below is the -90dBFS signal from my diy AD1853 DAC, 30KHz bandwidth, ignore vertical scale.
And I'm planning to build a diy low noise preamp and a 30KHz LPF, so that I can skip the 8903.
HI Banana,
this looks like only last two bits are switching.
Measuring such a signal is useless, exept maybe for MSB adjustment, but not to see the result.
-60 dB is better.
KONNICHIWA Bernhard SAN
I try again measurement with +20dB amplifier and Roland UA-30.
-60dB 997Hz sin-wave 16bit/44.1KHz input,
It is a result of measurement.
The vertical scale,please subtract 20dB.
The result of measurement is very good.
Jocko Homo said:
-90 dB is usless for distortion, but the more the signal looks like something that you can recognise, the better.
The AD1862 was good in that regard. The B-B DACs, wihtout a MSB trim.........no comment.
Jocko
I found 10% of tested PCM56 very good with adjustment and maybe 2% without, regardless of grade.
They vary a lot.
PCM58 all were a mess, 10 pieces tested.
Differences between TDA1541 are not so big, but the chip is not very good in this respect.
Hi Banana
How do you generate the -90dbfs signal ?
I have Cool Edit pro, and a spdif output on my PC card (creative Audigy) but it makes -80dbfs, not less...
Philippe
philbyx said:
Hi Banana
Philippe
I generate -90dBFS signal using "DAC Tester", which is kindly provided by a nice guy called Ulas on this forum.
I have problem using the SPDIF out of my cheapo Zoltrix soundcard. So I burn the test track onto a CDR and play it through my DVD player.
