how connect to subwoofer?
Hello, I want upgrade my system adding one sobwoofer.
How connect this?
I draw diagram, add the blue circuit is correct?
if not, how obteing signal for sw?
Alejo
Use a 5532 op amp with a regulated +15 and -15 volt supply. Take two 15K resistors to the - input of the op amp and provide your hot signal to these resistors from each channel. A 15K from the noninverting input to ground should work ok. Stick a pot from the inverting input to the output of say 50K or so. This will provide anything from less than unity to way more than unity gain for the buffer stage. This will provide the ability to control your low frequency and sum your signal.
Note* May need to check phase of low frequency output.
Ground the unused portion of your op amp. Some say it causes noise.
