Hi guys ... thought I'd try here, too! I am going to a homemade large format horn for my midrange. The horn has a 2" throat.
Will this adapter P AUDIO_PC5038 cause any problems using my 1.4" Altec 288 drivers? If necessary I can turn a thin wooden plate for the 1.4" to 1.5" conversion.
Thanks, Zene
Thanks, Zene
Match...
horn throat to driver exit diameter and slope (tangent angle). Discontinuties at the horn/driver joint should be avoided even if implemented by use of an adapter.
WHG
Thanks, Zene
WHG
Match Again
Then the slopes and diameters at both joints are a sufficient match.
WHG
I had a pair of 350hz edgarhorns that where designed for a 2" compression driver. I used that adaptor to make use of my Altec 288C 1.4" compression driver. I did not find any issues at all. We measusred them in a semi anaquic chamber and the responce was very smooth.
WHG
Getting a little confused. Unless the horn is custom made to a specific driver the angle of the driver throat is rarely the same as the horn throat. That doesn't justify adding another angle from an adapter, but I think it does bring up a question or twenty. The mfgs must have a good reason for unloading the throat of a driver with a conical flare.
Zene
Zene
Winslow ... then are you saying most horn throats, if they are close to 90 deg at the start, except for conical, are all a mismatch to the driver and inherently wrong? Tractrix does open fairly quickly, but it take an exact flare rate to closely match a particular driver.
Zene
Zene
For Good Reason
The driver bore, if conical, approximates a flare with an initially very large radius of curvature.
Within the driver bore and horn as well, an impedance transformation process is taking place. Unloading occurs only when signal frequency approaches horn cut-off or the horn is not present.
The reason for an adapter is cost, but all adapters are not created equal. The one you want to use is the one that has diameters and slopes that match those of the driver and horn attached.
Note there are also adapters that implement boundary transitions (round to rectangular) and wave front spreading (for pattern control). Use of these devices in an audiophile setting is contraindicated.
WHG
Zene
WHG
WHG
Yes, they were a good match up. And sounded good as well.
- Horn adapters
