Got a hole in my dust cap that is probably about 1/16" inch. The dust cap is really hard plastic. I was thinking about putting an extremely thin layer of glue over the small hole. I don't know if this is necessary.
Is the sound quality affected by the hole usually? Would it be better to try to cover it up?
http://www.lampizator.eu/SPEAKERS/PROJECTS/P24/P24_monster_speakers_raal_altec_lansing.html
HAve a look at the section on the midrange.
The driver is a VIFA D6.8 in a ported 2-way bookshelf system.
D6.8 sounds more like a HiVi part number...
dave
Looks like the D6.8 already has a vented dustcap, i'd use a small touch of PVA to seal the extraneous hole just to keep it from growing
dave
dave
I dont think they are holes
Look at Audiotechnology
They have used the same for many years
I reckon its to achieve at better connection between cone and dustcap
Could be it has some influence on ressonances too
btw, on my 8" woofers I have replaced dustcaps with foamplugs
At the time I thought it was a significant improvement
But may need crossover adjustments
Could be that the improvement was due to dustcaps being inverted, and not attached at voicecoil, but further up on the cone
A better dustcap attached at the voicecoil might be even better
Half a tabletennis ball could be used for smaller drivers
But if you need bigger dustcaps its quite easy to diy
I have used polyurethane glue(foam) and bits of perforated dustcloth, and a mold
http://www.audiotechnology.dk/image/8inch_cut.jpg
yes, when I look more closely, it appears those are extruded edges, for greater stiffness I guess.
Half a tennis ball is pretty heavy, relatively speaking, of course. Adding that much mass would significantly change the response. Molding one out of dustcloth is a good deal better, you could also raise the hf response by using thin aluminium.
- Hole in Dust Cap Affect Sound Quality ??
