I was having a similar problem with a 8600R. Worked fine for a year or so, till I suddenly got a hum in the right channel. No voltage on a testpoint at the right ripple filter. It was suggested to replace a mosfet and a zener diode which I did. Also replaced the tubes, as they could have caused the problem in the first place. Got voltage back again, but the hum remained, only at a higher pitch now. Checked all soldering, switched output transformers, replaced another zener diode (which appeared to be fine), resoldered many points on the right channel, all to no avail. Amp is unusable now. Looking at the forum, I'm not the first with this problem, seems to be a weak point with this amp. Any suggestions welcome. Thanks
