Bas,
If you check the specs, most hook-up wire is good to 600v, and the wire used for mains cable (in Europe) is often good for 900v - 1000v.
Do check the specs for yourself!
What I have done in the past is to buy sleeving and thread the HV cable through that as an extra safety precaution. Avoid PTFE sleeve as it's a bit stiff.
Connectors
Personally, I have come to hate them MIL plugs, although they should be OK for dry environments....( beleive me- I have long time bad experiences...)
Cannons and Winchesters etc are hard to get and expensive,--
Check out the Harting or ( Phoenix ) series HAN or STAF, - all designed for line voltage use and pin counts from 2 and upwards,..
excellent and reliable connectors..
available in Europe from Farnell, --among others...........
Neither did I.
Back in the early Nineties, RS was represent in Belgium by Mulder-Hardenberg, a Dutch company BTW, together with Miravox in Brussels.
They were about twice as expensive as RS in the U-K.
Do you know if they still sell straight to individuals?
TA.
While browsing RS-COMPONENTS.NL
Neither did I.
TA.
Hi Bas,
That's great news, now I really don't have an excuse to start building again.
Yes they do! Order today..ship the same day!
- Tubes / Valves
- High voltage umbilical and connectors / 1 box for PSU 1 box for amplifier in kit88
