High voltage (120-180V) output drivers
Hi Current???
I know that this thread is labled high voltage.
But, I would like to get some feedback on 2N5684/2N5685. Didn't want to make a whole new thread for this. These are something like 80V max, but are quite hefty when it comes to current. This device as I under stand can conduct 50A:att'n: I was wondering what the maximum LINEAR operating current is. I am estimating at or around 9-10A. Does anyone have any data sheets for these devices? (cross referenced to ECG 29 and ECG 30). Beta is around 15-20
Thinking of making a hi power sub amp, Hee Hee.....Thinking class G. :cool:
I use mje243/253 as vas and drivers and they seem to work well and for only $.38. The 100v vce rating is very padded. In my vce tester, which is a 340v (originaly 170v) 25ua supply I recently built to find an unknown transistor's vce, I found that transistors are rated for the worst possible vce. I have a 130v 2n3906 while most were 50 or so.
I have 30 something pairs of mje243/253 and the ones tested were all much above there 100v rating more like 160v.
I don't know exactly what this means but I did use a few controll transistors and found most would go 5 - 10% higher then there rated vce so whatever results I get I just subtract 10%.
The tester is an up down 120v 240v transformer rectified, with a 25ua 2n6517 ccs load.
Cheers
Hi all
The BD139/140's are good for up to 100V but not higher.
The best I've used so far for higher rails are the 160V 2SA968/2SC2268. These were Toshiba's originally, but are now supplied by Magnatec, available from RS. Last time I saw RS description still had Toshiba listed as the manufacturer. Must let them know this is wrong!
Magnatec appear to make "close equivalents". From my knowledge of the fab company I would be surprised if they have not done a good job at providing a good match to the Toshiba's. Have not got a Magnatec data sheet, but frequency response is similar to BD139/140 as measured at 1 MHz (this doesn't say much though).
cheers
John
Eva's suggested transistors are very good.
Related the BD139, a very good unit, was used for many years as drivers to Radio Frequency transmitters operating up to 30 Megahertz.
I know about people that have used it to 100 Megahertz FM transmitters too...of course it will loose power in that frequency.
Till 100 Volts it is very good.
regards,
Carlos
