Re: er.. where's the switcher?
hmm?
MosfetBoy said:er... that power supply is seriously lacking power switchers
hmm?
DJNUBZ said:Looks like it lacks a lot compared to a mid to high end amp.
whats it lacking?
The power supply for an amplifier is the source impedance/energy of the amp components you place after it . Low value / ratings ? lack of punch, lack of ability to supply that energy required when needed.
This is also true for the output stages of the amp.
Low switcher count/rating = weak amp, game over.
You'll find that the higher end amps have more switchers, providing lower resistance, giving the ability to switch higher currents. Mosfets de-rate themselves when warm/hot and you end up with maybe 40 to 60% of original rating. This is why alot of amps die as their supplies cant cope when hot.
SkinnyBoy said:I'm sure the build quality is the same... amplifier PCB layout isn't THAT critical.. AND YOUR IN A CAR FOR FRIKS SAKE!!!!
The amps PCB board layout is as critical or more critical than just using good parts.
A good analogy is to take two identical car using identical equipment.
Then have it installed by two different install shop. I can guarrantee you 1000% that they will sound different.
Why? basically, the physical position(s) of the parts on the PBC will determine one of the main outcome of how they will sound.
- General Interest
- Car Audio
- "high quality" car amp???
