High End Preamplifier
There are two power supplies, one digital and on analogue. The digital is +-5V for PGA2311. The other is for the PIC, and relay board and is +5V. If I roughly divide the current consumption for the analogue one,
PIC = 10mA
LCD+Backlight = 50mA
IR sensor = 5mA
Relay board (2 Relay on) = 75 mA
misc = 60mA
It sums up = 200 mA
The analogue supply is parallel that means total current capacity@5V = 500mA. That should be sufficient. Please somebody correct me if I am wrong.
Farooq
That is correct. I am using two separate tramsformers. Attached is the datasheet. 70040 is origional, 70020 is required to be used.
Somebody constructed already constructed it? How does it sound?
Farooq
  • talema2.pdf
Yes I have, which is why I recommended something that sounds 10 times better.
Here is my old one, collecting dust in an icecream tub.
I have one installed in an amp I gave to my mom in law.
