hifonics hifi1000.1d
This amp came in with two shorted output and some leaky PS FETs
I replace all PS FETs and remove the shorted output.Amp has + - 21.23
on the center leg of the rectifiers is that normal?Rail caps are rated for 60v.The out puts are IRF640n can i used irf540n or any other fet for test?
hifi
I think i had a solder bridge on the output section.ALL outputs in circuit
I install two new rectifers rail voltage is - + 37.6v.
Amp has good audio but PS FETS still getting hot out of the sink.I put the board back
in the sink and run it for about 20min with 500w 4ohm speaker.It seems to be ok
but am just wondering how hot should PS fets get for class d amps get out of the sink?
The Fets get to hot to touch in less than a minute.I test all four driver transistor out of the board and they tested good.This amp has a little board in the power supply with the pwm IC on it .THe number on it is scratch out but i can see it has about two 00 on it can that IC caused that problem?
