Hi-vi trinity 6 in a horn enclosure?
Anyone know if this driver will work in a horn box??
here are the specs
I just steal these on ebay :devilr:
here's some more info of the woofer from partsexpress
Woofer specifications: *Power handling: 40 watts RMS/80 watts max *VCdia: 3" *Znom: 4 ohms *Re: 3.2 ohms *Frequency range: 63-1,200 Hz *Fs: 63 Hz *SPL: 90 dB 2.83V/1m *Vas: .20 cu. ft. *Qms: 2.50 *Qes: .46 *Qts: .38 *Xmax: 2.7 mm.
sqlkev said:
is there any easy to use modeling program that I can play around with?
many thanks,
Look into the BIB, there was a small discussion using that driver in a BIB, but was not going to fit the appplication after all. There are a few people still lurking around wanting to see the outcomes of a project using that driver.
BIB dimensions
hivi6
Fs 63.000
Vas 0.2
Qts 0.380
Line Length 106.861
Folded Height 53.431
Vb 1.193
Sm 38.596
Depth 7.388
Width 5.224
zdriver 23.189
a-b-c 3.694
BIB dimensions
hivi6
Fs 63.000
Vas 0.2
Qts 0.380
Line Length 106.861
Vb 1.193
Sm 38.596
Depth 7.388
Width 5.224
zdriver 23.189
a-b-c 3.694
Thank you for the info,
anywhere I can get some drawings of such BIB?
Greets!
FYI, when I reverse calc BL using the published Cms I get a Sd that's considerably larger than the driver (~22.78" effective piston diameter Vs a 17.3 cm published overall dia.) and a BL best suited to compression horn loading, yet the 90 dB sens is about right with the PE specs, so not sure what's going on.
Calc'd based on Cms = 2.409 mm/N (published):
dia = ~22.78 cm/8.9685" ------ o.d. of driver is only 17.3 cm, so the rest are suspect!
Sd = ~407.55 cm^2
Mms = 265.3113 g
BL = 27
Anyway, scaled some dims off the PE picture:
effective outside dia. = ~13.1934 cm/5.1942"
effective inside dia. = ~7.252 cm/2.855"
calc'd:
Sd = 136.711 cm^2 - 41.305 cm^2 = 95.406 cm^2
BL = 6.3226 N/A
Cms = 4.3963E-04 mm/N
Mms = 14.5169 g
Sim of previously posted BIB: http://www.diyaudio.com/forums/attachment.php?s=&postid=1269969&stamp=1186116360
TC's BIB optimized for the T6:
L = 138"
zdriver = 30"
Sm = ~30.758"^2 (recommend ~4.687" W x 6.562" D)
a-b-c = ~3.281"
GM
