Because it uses the standard UAC2 Async protocol rather than a proprietary, block-transfer mode based protocol used by m2tech. For a discussion about why using block-mode is a bad idea (and the standard is far better), have a look e.g. at this post: http://www.diyaudio.com/forums/digi...sb-interface-audio-widget-12.html#post2829764
Apart from this, Xmos will work (without extra drivers) on both MacOS and Linux. Which are far better systems to consider for audio reproduction. When it comes to high-quality audio, windows is a problem to avoid, not a viable solution.
