Hi-end 845 with only two stage
yesterday evening I have started some measurement about 6HV5A used like 845 driver.
The schematic was very simple: inductance on anode, Rk = 100ohm, Ck = 470uF, Rg = 75Kohm and output capacitor 2.2uF on 33 or 100Kohm load.
With medium voltage operation (about 600V) these tubes give low sperformances because distortion is high 1.1% at 25Vrms.
The good result are obtain using 980V and 100ohm on catode to keep the power nead the 30w (35w is the maximun allowed), bias about 30mA.
With these value I have got the good 1% at 120Vrms on 33Kohm load.
The freq. response is limited to 50Hz(-3db) with 20H but it will be 10Hz(-3db) using 100H 50mA Sowter 8982.
The voltage amplification is 120/0.7=155x.
audiodesign has attached this image:
Click the thumbnail to see the original image.
Finally the first test result using 6HV5A to drive 845
6HV5A loaded by 20H (Rdc=70ohm) and Rk=100ohm Ck=220uF
950V 28mA
845 loades by Tango X-10S 10K/8ohm Vg=150v Rg=22Kohm
950V 100mA
10Vrms on 8ohm with 2% thd
Interstage 2.2uF // 0.33uF Audyn-Cap Plus
Very good sound
Very good voltage gain
Power can be increased using 1100V instead of 950v
Soon next test and photos
Hi Andrea,
I am right now in the process of building your 'New 845' with the EL34/845 combo.
This one looks a lot simpler. How does it compare? Can it be driven direct from a CD player
I am just about to finalise the power transformer order. Should I hold off? I would love to see a schematic of your power supply.
Rob
Thanks Andrea,
So how does it sound compared to your "New 845" and if you could build only 1, which would you choose?
I also noted that you initially had problem with noise due to gain and then added the DC rectification - do you have the same issues with this one?
Rob
This amplifier is in develop phase so some changes will be necessary to ear the final result.
In a first comparation test yesterady evening I like very much the sound of this new amp.
The my 845 amp. use Jensen copper film paper in oil interstage and this new two stage 845 use a MKP cap so a real comparation is not possible.
The my 845 amp. use Valve Art 845 and this new two stage use 845 Shuguang.
So a real comparation at this time is not possible but I will do this in the next weeks.
Administrator
Joined 2004
Interesting design Andrea, I'm working a two stage 211 based amplifier using the 5842/417A. Like yours also fixed bias and a 100H magnequest choke (exo-001) to load the 5842.. I have a pair of GE VT4C that will go in this amplifier.
Have not yet decided on the OPT..
Supplies per my usual practice will probably be regulated - might reconsider that if I end up using a parafeed configuration on the output stage.
Administrator
Joined 2004
audiodesign said:
In not normal use a 5842 to drive the 845 because the 5842 have too low voltage swing and too less voltage gain
Quite well aware of that, but I have 211/VT4C tubes in hand which have much higher mu (11) than the 845.. I was just commenting on the similarities, not suggesting you (or anyone to be clear) even consider the 5842 for this application.
I think even the D3A would be pretty marginal driving the 845, at least in triode connection even with a 1:2 step up IT.
I'll definitely check out what I can get the Lundahl amorphous core opt for in this country - it might be an excellent choice for my amplifier. :D
