I've just purchased some PCB's from ebay of the Leach150 poweramp. The parts list has some chinese text in it.
here's the link to the parts list:
http://www.diyzone.net/images2/LEACH1006BOM.XLS
The texts are pasted here in case the URL does not respond:
要用1W的
測試用
高頻迴授用 希望數值儘量接近
低頻迴授用 希望數值儘量接近
1N400X容易施工與折腳
2PIN端子
小散熱片
大散熱片
TO-3矽膠片
TO-220矽膠片
TO-3絕緣套
絕緣豆
12mm銅柱
25MM太長 24MM才剛好
2 PIN排針
2 PIN短路帽
L型散熱轉接鋁板
螺絲 M3*10mm
螺絲帽
Wish I knew chinese...
Could someone translate it for me to english?
Thanks,
Arie
要用1W的
測試用
高頻迴授用 希望數值儘量接近
低頻迴授用 希望數值儘量接近
1N400X容易施工與折腳
2PIN端子
小散熱片
大散熱片
TO-3矽膠片
TO-220矽膠片
TO-3絕緣套
絕緣豆
12mm銅柱
25MM太長 24MM才剛好
2 PIN排針
2 PIN短路帽
L型散熱轉接鋁板
螺絲 M3*10mm
螺絲帽
Thanks,
Arie
1W use of
Test
High-frequency feedback with the hope that value as close as possible
Low-frequency feedback with the hope that value as close as possible
1N400X easy construction and folding legs
2PIN terminal
Small heat sink
Large heat sink
TO-3 silicon-chip
TO-220 silicone film
TO-3 Insulating sleeve
Insulation beans
12mm Copper Cylinder
25MM was just too long 24MM
2 PIN Pin
2 PIN short cap
L-type aluminum plate heat relay
Screw M3 * 10mm
Screw cap
Test
2PIN terminal
Small heat sink
Large heat sink
TO-3 silicon-chip
Insulation beans
2 PIN Pin
2 PIN short cap
Screw M3 * 10mm
Screw cap
You need to have IE6 or higher and install the Google Toolbar Google Toolbar
Or use http://translate.google.com/
