Help with SRPP pre-
Hi Guys
Attached is a circuit published some 20 yrs ago which I built and had TX made but stalled the finish as the valves were too expensive at that time (for me any how).:whazzat:
I need to know what component values are necessary to change if I substitute V2 and V3 with 12AX7's as in V1 since I have just received a batch of NOS Ediswan 12AX7's.
keith birss
You'll end up with a very different baby if you substitute those tubes all with 12ax7....
first 2 tubes are ofcourse the phono amp the last one the "normal" preamp.
Since it is a phono amp..I would look for a phono amp design that uses all 12ax7 AND THEN build a different preamp...using whatever you fancy or can afford.
Bas
PS..are you the Keith that did dj'ing and rented out sound equipment?
diyAudio Senior Member
Joined 2002
That SRPP is a preamp designed by Rainer Zur Linde.
The ECC83 1 2 should be used here for correct gainscaling.
Mu of 100, 60 and 17 respectively.
If not a very noisy pre will result and if only ECC83/12AX7As are used to output impedance will be too high as well.
Not to mention the fact that you'd need to redesign half of the preamp as well.
Surely it must be possible to buy a pair of ECC81s/12AT7As and ECC82s/12AU7As in SA?
Cheers,;)
Joined 2002
In case only the line stage is considered an SRPP stage using a 12BH7A would be better still...
Actual results would depend on PS reguation which is tantamount to the SRPP topology.
There's a myriad of other choices for this service one can come up with with too.
Cheers,l;)
Thanks Frank Reinhard Dr G and Bass
you can stop twisting my arm now (there were no emoticons for tongue in cheek available).
I'll buy the damn things and wait some more for them to arrive ,like I said in an earlier thread with 4 professional students living at home my budget is thinner than the proverbial "....hair"
regards
keith
Joined 2002
the original amp is from K. Anzai (1969), think you kow his name.
Sure, I'm well aware of the history of the SRPP.
Thanks to Anzai and Jean Hiraga it got known in Europe many years before it was discussed in U.S. magazines together with its derivatives.
Out it it were born the optimised SRPP circuits, the mu-followers and ultimately the CSS loaded stages.
I had friends building the SRPP preamp by Zur Linde and it was
pretty good at the time.
Much better than the classic circuit of that era anyway. Yet it didn't beat my simpler resistively loaded preamp as I've shown on the forum on dynamic range and imaging.
Since then I experienced several SRPP circuits and still find it a very useful topology but it does need a very stiff PS and often gives best results with high Ri triodes.
Technically that makes a lot of sense as high Ri of the top half isolates the bottom part better hence the transition to the penthode/triode mu-follower making for a good CCS.
Cheers,;)
